Thunderbolt settings in X570 Aorus Pro bios
The bios has Thunderbolt Support settings and Pcie Tbt Support toggle, enable or disable.
So does this mean that I can have Thunderbolt via add-on card? I didn’t know they exist.
I don’t have this mobo but there are posts on other forums that say this board does have the header for it even though it isn’t listed as having it for the product on Gigabyte’s site. Look for a header labeled THB-C I think.
Perhaps another forum member can confirm.
Cheers!
Yeah mine has the solder points but no header.
Cheers!
Get a hot air station and make it happen :wink:
Ahahah, hey wait I do have soldering iron…
Well you’d be embarking in to uncharted territory for others brave enough to try.
