Thunderbolt ethernet stopped working - possible kernel issue?
Hello all,
I haven’t used this “use case” for a few months but I’ve run into an issue with my PC to PC connection done via the QNA-T310G1S (thunderbolt to 10 GbE)
Both devices have the QNA-T310G1S, has worked fine in the past. The current status, the connection leds don’t blink.
After doing some probing, I have found that both computers acknowledge the device is there.
For example:
That being said, I’ve noted that there are “unknown header types” and errors when I shutdown my PC…if they are at all related…
7:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06) (prog-if 00 [Normal decode])
	Subsystem: Gigabyte Technology Co., Ltd JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018]
	!!! Unknown header type 7f
	Memory behind bridge: 50000000-500fffff [size=1M] [32-bit]
	Kernel driver in use: pcieport
07:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06) (prog-if 00 [Normal decode])
	I/O behind bridge: 00006000-00006fff [size=4K] [32-bit]
	Memory behind bridge: 40000000-47ffffff [size=128M] [32-bit]
	Prefetchable memory behind bridge: 0000006403000000-0000006406ffffff [size=64M] [64-bit]
08:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018] (rev 06)
	Subsystem: Gigabyte Technology Co., Ltd JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018]
	Memory at 50100000 (32-bit, non-prefetchable) [size=256K]
	Memory at 50140000 (32-bit, non-prefetchable) [size=4K]
	Kernel driver in use: thunderbolt
	Kernel modules: thunderbolt
3f:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018] (rev 06) (prog-if 30 [XHCI])
	Subsystem: Gigabyte Technology Co., Ltd JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018]
	Memory at 50000000 (32-bit, non-prefetchable) [size=64K]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
40:00.0 PCI bridge: Intel Corporation JHL6240 Thunderbolt 3 Bridge (Low Power) [Alpine Ridge LP 2016] (rev 01) (prog-if 00 [Normal decode])
	Subsystem: QNAP Systems, Inc. JHL6240 Thunderbolt 3 Bridge (Low Power) [Alpine Ridge LP 2016]
	Physical Slot: 4
	Memory behind bridge: 40000000-404fffff [size=5M] [32-bit]
41:01.0 PCI bridge: Intel Corporation JHL6240 Thunderbolt 3 Bridge (Low Power) [Alpine Ridge LP 2016] (rev 01) (prog-if 00 [Normal decode])
42:00.0 Ethernet controller: Aquantia Corp. Device 80b1 (rev 02)
	Subsystem: QNAP Systems, Inc. Device 80b1
	Memory at 40440000 (64-bit, non-prefetchable) [size=64K]
	Memory at 40450000 (64-bit, non-prefetchable) [size=4K]
	Memory at 40000000 (64-bit, non-prefetchable) [size=4M]
	Expansion ROM at 40400000 [disabled] [size=256K]
	Kernel driver in use: atlantic
	Kernel modules: atlantic
appreciate any insight, WWED.
P.S. noting the issue related to wifi device…that may be a story for another time. That shit the bed on me.
P.P.S. let me know if there is any other info I can provide.
Update:
I have network activity leds on now. I can make an initial connection. When attempting to move a file, Caja is “preparing to transfer” and the network connection drops and cannot be revived/ reconnected.
