Threadripper Pro motherboard...ASUS vs Supermicro?
This is for a new UnRAID server I’m building. It’s going into a Supermicro CSE-836 chassis that I bought the PDB for which has the 4x8pin EPS 12V connectors but no PCIE connectors. Supermicro makes a cable to convert from EPS 8pin to PCIE 8pin though.
Specs:
3955WX w/ 128GB of ECC RAM.
Mellanox ConnectX-3 SFP+
1050 Ti for VM
P2000 for Emby
LSI 9211-8i HBA
USB 3.0 card for VM
I can’t decide which motherboard to get. I’m honestly not sure that I can actually supply all of the power connectors on the ASUS WS WRX80E-SAGE SE WIFI since I found out it has 1xPCIe 8pin, 2xPCIe 6pin, and 2xEPS 8pin.
With the 4xEPS 8pin connectors on the new PDB I think I’ll come up short unless I can split the last EPS 8pin to 2xPCIe 6pin connectors?
Something like this - PC power supply CPU EPS 8 pin to 2 PCI-e 8 (6+2) pin PCI Express Graphics Card Internet Power Splitter Cable, PSU CPU 8pin to 2 x GPU Power 8pin Power Adapter Cable - 8 inches - Newegg.com
The other option is to just go with the Supermicro M12SWA-TF as it only has 3xEPS 8pin connectors.
I’m looking for a bit of guidance as I don’t want to burn the house down or kill the server.
I’m coming from a CSE-846 running 2xE5-2630L v2’s so this will be a big upgrade.
Well l ordered a supermicro board from Newegg and they never filled the order.
So asus?
The extra Asus power connectors applymonly if you are using lots of devices that need pcie power like gpus
So it’d be fine if I left off the 2x6-pin PCIe connectors since the GPU’s I’m using are both under 75 watts?
Also, what are your thoughts on a Molex extension to get power to a USB 3.0 card and SSD inside the chassis?
The Supermicro PCB has 2 spare Molex connectors, a EPS 4-pin, and a EPS 8-pin but that’s it so Molex appears to be my only option.
You could do that but I would connect 1 pcie adapter to it if I was you, you dont need both for sure as 1 6 pin should provide more then enough.
As long as its thinner wire then the cable its coming from probably ok.
You know how those are pined out so you could make custom adapters to get what ever outputs you need.
Are you saying connect just the 8-pin PCIe and levae the 6-pin PCIe disconnected or that I need to plug in one of the 6-pin PCIe connectors?
If I can find a good splitter to get both of the 6-pin connectors from an 8-pin EPS I’ll do that but I hate getting some random cable and really don’t want to risk making one as I have no idea what I’m doing.
I had ordered the Supermicro board before I got a reply to this thread and had already shipped before I could cancel it so I guess I’ll try it out when I get a CPU and RAM in a couple of months.
I ordered through Wired Zone and it was drop shipped from Supermicro.
