Threadripper lm_sensors HALP
Thoughts all? I can’t seem to get any sensor data on the Gigabyte X399 with the 1950X.
Thanks!
What software are you trying?
lm_sensors in Fedora 26.
[root@threadripper ~]# sensors
iwlwifi-virtual-0
Adapter: Virtual device
temp1:        +33.0°C
Not sure if this is the overall CPU temp. On my Z170/6700K box, it does give me a breakdown of temps by cores though. The detection process doesn’t seem to recognise anything on the X399 board.
Update: Looks like I’m not alone.
This chap has got it work in Ubuntu after loading a specific module; will do some digging.
Hey @wendell if/when you get a chance on the Gigabyte board, do please let me know if you figure this one out in Fedora 26 please.
FYI The chap at Phoronix (see link in my previous post) mentioned loading a i87 kernel module in Ubuntu, but didn’t mention Fedora – also Googling didn’t yield much about that module… :confused:
https://github.com/groeck/it87?files=1
That what you looking for?
Awesome, thanks @Baz - I’ve posted my findings in an issue there, will see how far I get.
You checked if the module is loaded?
lsmod | grep it87
If it’s missing add it manually to /etc/sysconfig/modules/something.module
and see what happens, that’s what i’d try first
Made some decent progress -
Once I loaded the module and re-running sensors-detect
Trying family `ITE'...                                      Yes
Found unknown chip with ID 0x8733
Here’s some temp info
[root@threadripper it87]# sensors
iwlwifi-virtual-0
temp1:        +38.0°C
it8792-isa-0a60
Adapter: ISA adapter
in0:          +1.38 V  (min =  +0.00 V, max =  +2.78 V)
in1:          +1.51 V  (min =  +0.00 V, max =  +2.78 V)
in2:          +1.05 V  (min =  +0.00 V, max =  +2.78 V)
in3:          +1.98 V  (min =  +0.00 V, max =  +2.78 V)
in4:          +1.79 V  (min =  +0.00 V, max =  +2.78 V)
in5:          +1.50 V  (min =  +0.00 V, max =  +2.78 V)
in6:          +2.78 V  (min =  +0.00 V, max =  +2.78 V)  ALARM
3VSB:         +1.68 V  (min =  +0.00 V, max =  +2.78 V)
Vbat:         +1.57 V
fan1:         814 RPM  (min =    0 RPM)
fan2:           0 RPM  (min =    0 RPM)
fan3:        1024 RPM  (min =    0 RPM)
temp1:        +40.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
temp2:        -55.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = Intel PECI
temp3:        +39.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
intrusion0:  ALARM
There’s a TODO file in the Github repo for the it87 module which states that the AMD CPU temp sensor is reported as an Intel one. In any case, the CPU temp I’m getting looks way off.
Also for Fedora 26, I had to fix the Makefile prior to compiling, and this is my version
# For building for the current running version of Linux
TARGET		:= $(shell uname -r)
# Or specific version
#TARGET		:= 2.6.33.5
KERNEL_MODULES	:= /lib/modules/$(TARGET)
# KERNEL_BUILD	:= $(KERNEL_MODULES)/build
KERNEL_BUILD	:= /usr/src/kernels/$(TARGET)
#SYSTEM_MAP	:= $(KERNEL_BUILD)/System.map
SYSTEM_MAP	:= /boot/System.map-$(TARGET)
DRIVER := it87
# Directory below /lib/modules/$(TARGET)/kernel into which to install
# the module:
MOD_SUBDIR = drivers/hwmon
MODDESTDIR=$(KERNEL_MODULES)/kernel/$(MOD_SUBDIR)
obj-m	:= $(patsubst %,%.o,$(DRIVER))
obj-ko  := $(patsubst %,%.ko,$(DRIVER))
MAKEFLAGS += --no-print-directory
ifneq ("","$(wildcard $(MODDESTDIR)/*.ko.gz)")
COMPRESS_GZIP := y
endif
ifneq ("","$(wildcard $(MODDESTDIR)/*.ko.xz)")
COMPRESS_XZ := y
endif
.PHONY: all install modules modules_install clean
all: modules
# Targets for running make directly in the external module directory:
modules clean:
  @$(MAKE) -C $(KERNEL_BUILD) M=$(CURDIR) $@
install: modules_install
copy:
        mkdir -p $(MODDESTDIR)
        cp $(DRIVER).ko $(MODDESTDIR)/
ifeq ($(COMPRESS_XZ), y)
        @xz -f $(MODDESTDIR)/$(DRIVER).ko
endif
Run the following to compile the module
make
make copy
modprobe it87
# confirm module is loaded
lsmod | grep it87
Here’s a reference on how to load modules in Fedora 26 as well.
Hi…i am a new user here. As per my knowledge the X399 AORUS Gaming 7 for AMD Threadripper processors is quite a competent board. This AMD X399 motherboard features three M.2 slots, Realtek ALC1220 audio, Killer E2500 networking, USB 3.1 Gen2 Type-C connectivity, Intel 802.11ac WiFi and Bluetooth, UEFI DualBIOS, server-level power chokes, and other high-end motherboard features.
pcb assembly china
Along with help from the driver devs @ Github, I’ve managed to seemingly get this to work
[root@threadripper it87]# modprobe it87 force_id=0x8686 ignore_resource_conflict=1
it8686-isa-0a60
in0:          +1.50 V  (min =  +0.00 V, max =  +3.06 V)
in1:          +1.66 V  (min =  +0.00 V, max =  +3.06 V)
in2:          +1.15 V  (min =  +0.00 V, max =  +3.06 V)
in3:          +2.18 V  (min =  +0.00 V, max =  +3.06 V)
in4:          +1.97 V  (min =  +0.00 V, max =  +3.06 V)
in5:          +1.66 V  (min =  +0.00 V, max =  +3.06 V)
in6:          +3.06 V  (min =  +0.00 V, max =  +3.06 V)
3VSB:         +3.70 V  (min =  +0.00 V, max =  +6.12 V)
Vbat:         +3.46 V
fan1:           0 RPM  (min =    0 RPM)
fan3:        1095 RPM  (min =    0 RPM)
fan4:           0 RPM  (min =    0 RPM)
fan5:           0 RPM  (min =    0 RPM)
temp1:        +43.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
temp2:        -55.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
temp3:        +41.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
temp4:       -128.0°C  (low  = +106.0°C, high = +106.0°C)
temp5:        -51.0°C  (low  = +62.0°C, high = -74.0°C)  sensor = thermistor
temp6:        +60.0°C  (low  =  -1.0°C, high =  -1.0°C)
intrusion0:  ALARM
iwlwifi-virtual-0
temp1:        +41.0°C
it8686-isa-0a40
in0:          +1.38 V  (min =  +0.00 V, max =  +3.06 V)
in1:          +2.00 V  (min =  +0.00 V, max =  +3.06 V)
in2:          +2.02 V  (min =  +0.00 V, max =  +3.06 V)
in3:          +2.00 V  (min =  +0.00 V, max =  +3.06 V)
in4:          +1.21 V  (min =  +0.00 V, max =  +3.06 V)
in5:          +0.97 V  (min =  +0.00 V, max =  +3.06 V)
in6:          +1.21 V  (min =  +0.00 V, max =  +3.06 V)
3VSB:         +3.31 V  (min =  +0.00 V, max =  +6.12 V)
Vbat:         +3.05 V
fan1:        1430 RPM  (min =    0 RPM)
fan3:           0 RPM  (min =    0 RPM)
temp1:        +44.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
temp2:        +54.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
temp3:        +33.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = AMD AMDSI
temp4:        +43.0°C  (low  = +127.0°C, high = +127.0°C)
temp5:        +40.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
temp6:        -55.0°C  (low  = +127.0°C, high = +127.0°C)
intrusion0:  ALARM
Not only did I need to force the module ID, like above, but also correct my version of the Makefile to copy the compressed module *.ko.xz over, not just *.ko in Fedora.
Hi all - I’ve worked with the author of the it87 module to get support working for the Gigabyte X399 board. Thanks to @baz and CC @wendell
With the new module loaded, output looks like https://github.com/groeck/it87/issues/49#issuecomment-331392857
Here are the fixes, quick summary -
  • There are two chips — IT8792E and the IT8795E — both having the same ID (LOL WUT!), so sensors detects it as IT8792. In reality the block diagram for the Gigabyte board lists a IT8795 chip.
  • the IT8792 is connected to SYS_FAN4 (fan3) and SYS_FAN5_PUMP (fan1) from my testing.
  • The IT8686 has CPU_FAN (fan1) which shows my H115i’s pump rpm.
  • Noticed in0 reporting odd values at times on idle, but my latest test with the current version on Github reports VCore correctly. It also seems both chips are connected to VCore.
  • CPU temp is reported via IT8686 temp3.
  • We had an issue that loading the driver would cause fan3 to stop spinning; this has now been resolved. The author needed a full acpidump and some other troubleshooting to figure this out. When the fan stopped running a quick cat /sys/class/hwmon/hwmon1/pwm1_enable would get it to run again for a short while.
      [root@threadripper it87]# modprobe it87 ignore_resource_conflict=1
      it8792-isa-0a60
      in1:          +1.50 V  (min =  +0.00 V, max =  +2.78 V)
      in2:          +1.04 V  (min =  +0.00 V, max =  +2.78 V)
      in3:          +2.00 V  (min =  +0.00 V, max =  +2.78 V)
      in4:          +1.78 V  (min =  +0.00 V, max =  +2.78 V)
      3VSB:         +3.33 V  (min =  +0.00 V, max =  +5.56 V)
      Vbat:         +3.14 V
      fan1:        1138 RPM  (min =    0 RPM)
      fan3:        1048 RPM  (min =    0 RPM)
      temp1:        +48.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
      temp3:        +45.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
      intrusion0:  ALARM
      iwlwifi-virtual-0
      temp1:        +46.0°C
      it8686-isa-0a40
      in0:          +1.39 V  (min =  +0.00 V, max =  +3.06 V)
      3VSB:         +3.34 V  (min =  +0.00 V, max =  +6.12 V)
      Vbat:         +3.07 V
      fan1:        1430 RPM  (min =   10 RPM)
      temp2:        +57.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
      temp3:        +37.0°C  (low  =  +0.0°C, high = +70.0°C)  sensor = AMD AMDSI
      temp4:        +47.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
      temp5:        +43.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
      temp6:        -55.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
      intrusion0:  ALARM
