So I'm looking at doing custom liquid cooling. This will be my first time doing a custom circuit. So to beginning im looking at spending around 200usd for the Rad, 1 CPU block, 1 GPU block, piping, coolant, pump, and reservoir. So my thoughts right now are these products
So right now i lack fittings so recommendations on those would be great as well as some compatibility checking by someone other then my self as im new to this.
My current system is as follows
Case- Nzxt phantom 410
CPU- I7 4770k
GPU- galaxy GTX 570(upgrades when maxwell comes out)
Looks like a nice loop though generally speaking people don't tend to use GPU only blocks because they will still require heatsinks and active cooling on the VRMs and memory. If it were me, i would try to find a full cover block for the gpu, or not do it, but this is of course up to you. Also note that a 240 rad is about the minimum for a CPU + GPU loop so you won't have much overclocking headroom left on it.
There are 6 1/2" barb fittings included in the kit. So this will be enough to get a basic loop going. If you want to use the primoflex tubing, you will have to put the tubing in warm water so it can stretch over the barbs, once in place the tubing then won't move again..
You will have to add some if you want to use the active cooling on the maximus 6. As far as i know any G1/4 fitting will fit, except for koolance because they have their own version of G1/4 (source Dazmode: http://youtu.be/81ABeROi4OY)
As for what fittings to use, i personally have only used compression fittings (which are more expensive than barbs, so this information could be obsolete). But the ones i have tried are Bitspower, TFC and monsoon. Bitspower are great but really expensive, tfc i found hard to get grip on to properly screw them in and their rotaries were extremely hard to rotate, and monsoon was really easy to use because of the included tool and is relatively affordable.
Just to be sure you could add anti corrosive and anti algae.
