So as it was suggested in the Lounge or Discord, as Kiwis we like Marmite So it was suggested that i/other kiwis to see if it was a good alternative to Thermal paste.(i think it was @Skelterz said to do it, something he would do ) Jay2Cents has done a video on using some alternatives, like Toothpaste Peanut Butter and some others.
Video:
So I need a few More items, Please suggest below and they have to be available in NZ
This List will be updated as suggestions are picked * Marmite * Nutella ( @SoftPoison) * Bluetack (@SoftPoison)
Testing I will Be Testing with and AMD A8 6600k (Stock Speeds) cooled with a Gammaxx 200T I will be using Intel Bun Test 2.54 with the setting on standard and 20 times to run set. On Windows 7 32bit with PAE patch to address the 8GB of ram (2GB dedicated to the GPU) I will be monitoring the CPU temp using HWmonitor and also recording the room temperature to see the Delta.
If you want me to ass more tests or change they way I'm testing, I'm open to suggestions
I am so happy you are doing this, so I will be using the American equivalent, Easy Cheese. :) I'll post up here once get the chance, I look forward to your results
