Was I correct that the setting I would set to make it hibernate to be in " /etc/systemd/logind.conf" ?
You would have to be specific about what you put there. logind may not deal with the issue that you are looking for which is actually on a kernel and initramfs level.
Take a look at the archwiki link. And give couple of those things a try.
If you are running SystemD, then this may be a better solution.
https://wiki.archlinux.org/index.php/Power_management#Sleep_hooks
I believe ubuntu 18.04 is systemd could be wrong again dont linux much
It is
It is. Look at those links and read them. Try some things. Remember what you tried. If you are still having issue, then let us know what you have actually tried.
Since you are new to the *nix world, there are many ways to solve issues, some better than others. So you will need to be detailed of what you did, like the commands you used, the files you edited, and what you put in those files.
Also dmesg and journalctl are your friends. These daemons detail what is going on with your system and log errors.
What is the best way to view Ryzen CPU clock speed? So that I can see if boost and downclocking is working
I am using Ubuntu 18.04 and have a Ryzen 1600
For reasons I needed to change the scaling governor to Performance.
I had a āPermission Deniedā result so I did āsudo -iā and attempted to change the governor again - This then worked.
But after this (and even after a reboot) When I open up a terminal window I now get this at the topā¦
bash: /home/james/.bashrc: line 97: unexpected EOF while looking for matching `)ā
bash: /home/james/.bashrc: line 118: syntax error: unexpected end of file
Iām new to Linux so confused why this is now appearing
What does your .bashrc look like?
Mind posting it here?
The system does not like whatās going on with those line numbers it is telling you about.
# ~/.bashrc: executed by bash(1) for non-login shells.
# see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
# for examples
# If not running interactively, don't do anything
case $- in
*i*) ;;
*) return;;
esac
# don't put duplicate lines or lines starting with space in the history.
# See bash(1) for more options
HISTCONTROL=ignoreboth
# append to the history file, don't overwrite it
shopt -s histappend
# for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
HISTSIZE=1000
HISTFILESIZE=2000
# check the window size after each command and, if necessary,
# update the values of LINES and COLUMNS.
shopt -s checkwinsize
# If set, the pattern "**" used in a pathname expansion context will
# match all files and zero or more directories and subdirectories.
#shopt -s globstar
# make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
# set variable identifying the chroot you work in (used in the prompt below)
if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
debian_chroot=$(cat /etc/debian_chroot)
fi
# set a fancy prompt (non-color, unless we know we "want" color)
case "$TERM" in
xterm-color|*-256color) color_prompt=yes;;
esac
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
#force_color_prompt=yes
if [ -n "$force_color_prompt" ]; then
if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
# We have color support; assume it's compliant with Ecma-48
# (ISO/IEC-6429). (Lack of such support is extremely rare, and such
# a case would tend to support setf rather than setaf.)
color_prompt=yes
else
color_prompt=
fi
fi
if [ "$color_prompt" = yes ]; then
PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
else
PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
fi
unset color_prompt force_color_prompt
# If this is an xterm set the title to user@host:dir
case "$TERM" in
xterm*|rxvt*)
PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
esac
# enable color support of ls and also add handy aliases
if [ -x /usr/bin/dircolors ]; then
test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
alias ls='ls --color=auto'
#alias dir='dir --color=auto'
#alias vdir='vdir --color=auto'
alias grep='grep --color=auto'
alias fgrep='fgrep --color=auto'
alias egrep='egrep --color=auto'
fi
# colored GCC warnings and errors
#export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01'
# some more ls aliases
alias ll='ls -alF'
alias la='ls -A'
alias l='ls -CF''
# Add an "alert" alias for long running commands. Use like so:
# sleep 10; alert
alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert$//'\'')"'
# Alias definitions.
# You may want to put all your additions into a separate file like
# ~/.bash_aliases, instead of adding them here directly.
# See /usr/share/doc/bash-doc/examples in the bash-doc package.
if [ -f ~/.bash_aliases ]; then
. ~/.bash_aliases
fi
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if ! shopt -oq posix; then
if [ -f /usr/share/bash-completion/bash_completion ]; then
. /usr/share/bash-completion/bash_completion
elif [ -f /etc/bash_completion ]; then
. /etc/bash_completion
fi
fi
If I counted correctly line 97 is
Add an āalertā alias for long running commands. Use like so:
and line 118 is fi
the fi
above the last fi
, Not the last fi
. As the last fi is line 119
The thing is, I havenāt edited the .bashrc file myself - So I donāt know why this has happened
@jrwagh333 How about pasting the file as preformated text (edit original post) so itās easier to read and count lines.
To make sure my counting was right, I used pastebin.
Pastebin also does syntax highlighting.
Just made a paste. It will expire in a week.
I wish I could find the bashrc that Ubuntu uses in 18,04 online so I can compare. ( I donāt Ubuntu )
The fi
that the error is complaining about belongs to bash autocompletion.
I edited your post to make it more readable.
You can post code blocks by nesting inside three backticks like this
Paste Code here
Debian Stretch:
Install nvidia 390.xx drivers from backports
Install steam, install fails: needs 32-bit drivers
Install libgl1-nvidia-glx:i386, install fails: needs nvidia 384 dependencies
Install dependencies, dependencies fail: you have 390.XX drivers
Remove 390.xx drivers
Reinstall nouveau
Blackscreen, add nomodeset to boot
Back in
granted this is my own fault for pulling the new drivers from the backports and expecting no hiccups, but 7-months on debian with zero issues; my confidence was high. lesson learned.
Decided to play around with lxc. It doesnāt seem to be going well. Host is Fedora 28. After some searching it appears to either be an issue with SELinux or a bug or a combination of the two.
Basically this is what I get when trying to create a Fedora container:
[admin@homeserver]$ sudo lxc-create -t fedora -n fedora-c1
Host CPE ID from /etc/os-release: cpe:/o:fedoraproject:fedora:28
Checking cache download in /var/cache/lxc/fedora/x86_64/28/rootfs ...
Cache found. Updating...
chroot: failed to run command āyumā: No such file or directory
Update finished
Copy /var/cache/lxc/fedora/x86_64/28/rootfs to /var/lib/lxc/fedora-c1/rootfs ...
Copying rootfs to /var/lib/lxc/fedora-c1/rootfs ...
Storing root password in '/var/lib/lxc/fedora-c1/tmp_root_pass'
chpasswd: cannot open /etc/passwd
Expiring password for user root.
passwd: Libuser error at line: 425 - Error replacing `/etc/passwd': Permission denied.
passwd: Error
installing fedora-release package
sed: can't read /var/lib/lxc/fedora-c1/rootfs/etc/sysconfig/init: No such file or directory
Container rootfs and config have been created.
Edit the config file to check/enable networking setup.
The temporary root password is stored in:
The root password is set up as expired and will require it to be changed
at first login, which you should do as soon as possible. If you lose the
root password or wish to change it without starting the container, you
can change it from the host by running the following command (which will
also reset the expired flag):
chroot /var/lib/lxc/fedora-c1/rootfs passwd
I canāt log in to the container using the temporary password, and I canāt change the password from the host.
Anyone have experience doing this?
