Or do you mean the menus path that Diff told you to travel down is not there?
Or the content that Diff told you to find is not there?
I thought Netrunner Rolling defaulted to KDE.
Here is how you can change the SDDM theme.
Uhhh. Where would I find that?
Or never mind.
The sad part about this is that you are using a German distro, and the distro is not well engineerd.
Thats really retarded I shouldnât have to edit fucking config files in SDDM to get a good login for my OS.
Another reason KDE pisses me off.
Now I can fix 2 manjaro laptops I was gunna wipe today.
Itâs your distroâs fault that it uses a non-standard conforming theme. KDE has the ability to change SDDM themes in the system settings without editting config files.
So im having a pretty bad ram leak that i cant seem to figure out. Almost 3GB of ram is unaccounted for and its making it really hard to multi task
sysinfo
https://paste.fedoraproject.org/paste/02QlihOJE~8U9U~EolYFzA
Okay, so what I did once which sorta helped me was to compile a kernel myself with some options for the AMD Graphics.
Here is what I would conjure up:
How many snapshots are on that btrfs system?
sudo btrfs sub list / | wc -l
Also, I may be encountering something similar, but Iâm not sure. Iâll have to do some more testing. (Iâm seeing slightly high usage, but Iâve got 32GB on my system, so itâs harder to tell.)
Is it possible to get this thread stickied? I am forever having small troubles with Linux, being a new user. So having this post at the top for myself, other new users, and even more experienced users would be great
zero snapshots
Hmmmmmm⌠Thatâs interesting.
Iâm not sure now. Iâm going to have to try to reproduce it.
alright. Im gonna sit and play with it for a bit to figure out whats going on
Fresh boot (Not even past SDDM) - 300M
Login - 800M
Starting Chromium - 1.5G
about what i would expect so far
Reinstalled fedora because the memory leak was just really bad
hopefully this goes better
Linux people, Just set up my wifes XPS 15 5790 and set up dual book Ubuntu 18.04LTS and Win10. Whenever I close the lid it doesnât wake up correctly (I believe the default for ubuntu is to suspend the os)
Is there an easy fix for this?
Does anyone know if hibernate or something would work better.
I believe the file that controls this is /etc/systemd/logind.conf not 100% on that but seems to be that from the searches I have don so far.
Does it have an nVidia GPU? If so , then that is a known bug with the nVidia driver.
If not, then you need to go into the setting app for Unity (or Gnome?) and look at power setting. You can set what you would like to happen.
In general, sleep is iffy on some systems due to how ACPI was not implemented to the actual specification. The best bet would be to hibernate (need sufficient swap space).
**Edit. Meant to say sleep is iffy.
It has a 1050ti and igpu I did the " ubuntu-drivers autoinstall" and i believe it installed Nvidia X server, and i set the gpu to use the igpu by default through that, the issue still happens with that setting
The sleep issue has been a bug for a long time with the nVida driver. I donât think that they will ever fix it to be honest.
Try disabling the 1050 in BIOS and see what happens. Otherwise. Hibernate is your best bet. Would invest in an SSD if you have not.
It has a 970 evo 1tb i dont use spinning rust in anything but a storage server
