What is the expected max transfer speed of an NFS Share over a residential router? Im clocking in at 15MB/s
Is there a master/ultimate exports file with a list of examples (kinda like the bash_aliases)
Really depends.
That is pretty good. NFSv4 or older?
I would look at the Red Hat docs as they are very extensive. You can mess yourself up if you donāt know what your are doing.
Otherwise, ArchLinux wikiā¦
https://wiki.archlinux.org/title/NFS#Tips_and_tricks
NFSv4, and i canāt get it to consistently mount. Iām trying move all my SMB shares to NFS.
VMs in the same machine transfer at 50-65MB/s
Soā¦ I finally got a bit of time on my hand to reinstall my PC, been wanting to do that for way too longā¦
Anyway, I am running into some issues. So I booted the Fedora KDE 36 Live USB (yes I know itās technically Beta butā¦ not for long), and was going into the Partition Manager just to check whatās there currently, so I wouldnāt nuke my /home
partition, and Iām seeing this:
So when I installed this thing years ago I was wanting to have separate partitions for root and home. But it seems what instead happened is that it created two volumes(?) and put them in a single partition?
Is there any way to rectify that without having to re-format the entire drive?
And if not, is there still a way to get the Fedora installer to install over the old Fedora install without touching the home volume?
Iām a little lost here why this even happened in the first place since Iām pretty sure I was creating two partitions back then but yeahā¦ IDK.
Also another odd issue. I still have a Windows drive in this PC (I shrunk the Windows partition and use the rest of the drive as an ext4 partition for games), and I pulled the SATA plug to be safe during installation.
But now the old Fedora install wonāt boot unless I reconnect that drive? I meanā¦ what? There is nothing on that drive that has anything to do with booting, but the system just boots into a maintenance mode insteadā¦?
On another node, like half a year ago I mentioned how DNF seems to have lost track of my manually installed packages. Well, this is what happens when I dnf history userinstalled
on the Live USB bootā¦
[liveuser@localhost-live ~]$ dnf history userinstalled
Packages installed by user
aajohan-comfortaa-fonts-3.101-4.fc36.noarch
anaconda-36.16.2-4.fc36.x86_64
anaconda-install-env-deps-36.16.2-4.fc36.x86_64
anaconda-live-36.16.2-4.fc36.x86_64
chkconfig-1.19-2.fc36.x86_64
dracut-live-055-8.fc36.1.x86_64
fedora-release-kde-36-0.16.noarch
fuse-2.9.9-14.fc36.x86_64
initscripts-10.15-1.fc36.x86_64
kde-l10n-17.08.3-12.fc36.noarch
kernel-5.17.0-0.rc7.116.fc36.x86_64
kernel-modules-5.17.0-0.rc7.116.fc36.x86_64
kernel-modules-extra-5.17.0-0.rc7.116.fc36.x86_64
langpacks-en-3.0-21.fc36.noarch
libreoffice-draw-1:7.3.0.3-3.fc36.x86_64
libreoffice-math-1:7.3.0.3-3.fc36.x86_64
mariadb-connector-c-3.2.6-1.fc36.x86_64
mariadb-embedded-3:10.5.13-1.fc36.x86_64
mariadb-server-3:10.5.13-1.fc36.x86_64
mediawriter-4.2.2-4.fc36.x86_64
Soooā¦ thanks DNF?
Possible that lock means its encrypted?
pv
is an lvm physical volume. It looks like thereās a luks container in the pv. Decrypt that and you should see your volume group(s), logical volumes and filesystems.
Yeah Iām fairly sure I set it to encrypt, but only on the home partitionā¦ I didnāt know that would result inā¦ well this. And I donāt think there was a warning about this either But well, whatās done is done. Just wondering if I can fix thatā¦
How would I do that on the Live system?
If all goes bad I might just nuke my Windows drive (and the games on it, RIP) to install there and move everything out of /home over later But Iād like to keep that as a last resort (never know when I might need a Windows install).
In the GUI, idk, right click on the lock or double click on it. Try stuff until it asks you for a passwordā¦
In a terminal, I donāt remember the specific command arguments off the top of my head. The command is cryptsetup
though:
Output of lsblk
would be helpful.
I believe cryptsetup luksOpen
is what you want. You need to find the device name though.
Yeah thatās what I tried, click just selects it, doubleclicking just opens the properties, right-click ā mount is greyed out
Checked that earlier but didnāt see anything helpful:
[liveuser@localhost-live ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 2G 1 loop
loop1 7:1 0 7G 1 loop
āālive-rw 253:3 0 7G 0 dm /
āālive-base 253:4 0 7G 1 dm
loop2 7:2 0 32G 0 loop
sda 8:0 0 465.8G 0 disk
āāsda1 8:1 0 200M 0 part
āāsda2 8:2 0 1G 0 part
āāsda3 8:3 0 464.6G 0 part
sdb 8:16 1 7.3G 0 disk
āāsdb1 8:17 1 2.1G 0 part /run/initramfs/live
āāsdb2 8:18 1 9.9M 0 part
āāsdb3 8:19 1 20.8M 0 part
zram0 252:0 0 8G 0 disk [SWAP]
Checked the man page to see if I can find anything non-destructive before using it. Tried cryptsetup status /dev/sda3
and the same with sda, both tell me Device not found
I havenāt messed with luks in a whileā¦
Whatās in /dev/mapper
[liveuser@localhost-live ~]$ ls /dev/mapper -lah
total 0
drwxr-xr-x. 2 root root 100 Apr 3 14:17 .
drwxr-xr-x. 21 root root 4.4K Apr 3 14:17 ..
crw-------. 1 root root 10, 236 Apr 3 2022 control
lrwxrwxrwx. 1 root root 7 Apr 3 14:17 live-base -> ../dm-4
lrwxrwxrwx. 1 root root 7 Apr 3 14:17 live-rw -> ../dm-3
cryptsetup isLuks /dev/sda3
[liveuser@localhost-live ~]$ cryptsetup isLuks /dev/sda3
Device /dev/sda3 does not exist or access denied.
[liveuser@localhost-live ~]$ sudo !!
sudo cryptsetup isLuks /dev/sda3
[liveuser@localhost-live ~]$ sudo cryptsetup isLuks /dev/sda3
Seems to return nothing?
Sorry, what is the exit code of that command?
Also, try running: sudo lvscan -a; sudo pvs; sudo vgs; sudo lvs
[liveuser@localhost-live ~]$ echo $?
1
[liveuser@localhost-live ~]$ sudo lvscan -a; sudo pvs; sudo vgs; sudo lvs
inactive '/dev/fedora_localhost-live/root' [50.00 GiB] inherit
inactive '/dev/fedora_localhost-live/home' [406.66 GiB] inherit
inactive '/dev/fedora_localhost-live/swap' [7.90 GiB] inherit
PV VG Fmt Attr PSize PFree
/dev/sda3 fedora_localhost-live lvm2 a-- 464.56g 0
VG #PV #LV #SN Attr VSize VFree
fedora_localhost-live 1 3 0 wz--n- 464.56g 0
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
home fedora_localhost-live -wi------- 406.66g
root fedora_localhost-live -wi------- 50.00g
swap fedora_localhost-live -wi------- 7.90g
I also just noticed something. In the partition manager thereās the fedora_localhost-live on the left, which is actually the LVM partition on that drive. It tells me itās mounted and so are the individual volumes:
Butā¦
[liveuser@localhost-live ~]$ ls -lah /run/media/liveuser/
total 0
drwxr-x---+ 2 root root 40 Apr 3 14:17 .
drwxr-xr-x. 3 root root 60 Apr 3 13:57 ..
Iām confused
It looks like fedora live somehow inherited your pre-existing logical volumes which I donāt really understand.
Good news is that it looks like you did separate your home folder as intended.
Iāve got to go, but there are definitely others here who can help you through your lvm issues. Iām not very fresh with that stuff right now.
Fedora probably detected the partition on the Windows drive and put it in /etc/fstab to automatically mount it, in case you want to use it. If a file system in fstab canāt be mounted, the system drops to single-user mode to let you sort it out. It doesnāt know which partitions are important, and which are not.
Yeah I did figure that, but itās still in one partition even if itās 2 volumes. And Iām not sure if that helps me install F36 over the original F33 volume
When using the ācustomā mode in the installer, all the partitions on that drive also show up and I can sorta set up the mount points myself:
And as long as I leave āReformatā unchecked that should leave the data on it untouched? But for some reason I canāt do btrfs on the root partition/volume (which was one of the reasons for the reinstall, just to play around with it):
Is btrfs not allowed on an LVM volume? Because by default new mounts points are created using btrfs when creating everything from scratch.
Yeah thatās what I was thinking although I am sure it was definitely not on automount (did show up in the Dolphin sidebar tho), so why it holds up there is a bit weird to meā¦ not that it matters much though.
The fsck fs_passno (number in sixth field of fstab) being non-zero and non-blank can cause a boot failure, too, even if the file system is set to noauto.
Hmā¦ so the Fedora installer has a secondary tool for partitioning (Blivet GUI, seems to be aimed at more versed users). And in there, I can actually delete the root volume and Iām getting the 50 gigs as āfree spaceā, but they are still inside the LVM group and I donāt seem to be able to shrink that?
And when I create a btrfs partition on that freespace (Blivet lets me do that, the other tool doesnāt as per above), it looks like this:
Which looks weird and I donāt know if thatās correct (the number seems to randomise everytime I delete/create a btrfs volume there).
Ugh, man this is really bothering me cause I had a really good run with Fedora so far
