Uh I feel like something is wrong on my system…
[tarulia@localhost]~% sudo useradd mocktest
[sudo] password for tarulia:
(2021-04-13 18:30:27:935436): [sss_cache] [confdb_get_enabled_domain_list] (0x0040): Failed to get [domains] from [sssd], error [2] (No such file or directory)
(2021-04-13 18:30:27:935483): [sss_cache] [init_domains] (0x0020): Could not initialize domains
(2021-04-13 18:30:27:943353): [sss_cache] [confdb_get_enabled_domain_list] (0x0040): Failed to get [domains] from [sssd], error [2] (No such file or directory)
(2021-04-13 18:30:27:943407): [sss_cache] [init_domains] (0x0020): Could not initialize domains
useradd: user 'mocktest' already exists
I actually just noticed that same message on the DNF History entry when I installed mock earlier…
[tarulia@localhost]~% dnf history info 641
Transaction ID : 641
Begin time : Tue 13 Apr 2021 04:00:09 CEST
Begin rpmdb : 3101:72f5f804e81979f91e13078da2b604fc3bff7c0d
End time : Tue 13 Apr 2021 04:00:13 CEST (4 seconds)
End rpmdb : 3110:37685be32032e3bb52bb6f5259e7f1490961407c
User : Tarulia <tarulia>
Return-Code : Success
Releasever : 33
Command Line : install mock
Comment :
Packages Altered:
Install distribution-gpg-keys-1.51-1.fc33.noarch @updates
Install dnf-utils-4.0.18-1.fc33.noarch @updates
Install mock-2.9-1.fc33.noarch @updates
Install mock-core-configs-34.2-1.fc33.noarch @updates
Install mock-filesystem-2.9-1.fc33.noarch @updates
Install python3-babel-2.8.1-1.fc33.noarch @updates
Install python3-jinja2-2.11.3-1.fc33.noarch @updates
Install python3-templated-dictionary-1.1-1.fc33.noarch @updates
Install python3-pyroute2-0.5.6-4.fc33.noarch @fedora
Scriptlet output:
1 (2021-04-13 4:00:10:455592): [sss_cache] [confdb_get_enabled_domain_list] (0x0040): Failed to get [domains] from [sssd], error [2] (No such file or directory)
2 (2021-04-13 4:00:10:455673): [sss_cache] [init_domains] (0x0020): Could not initialize domains
3 (2021-04-13 4:00:10:463313): [sss_cache] [confdb_get_enabled_domain_list] (0x0040): Failed to get [domains] from [sssd], error [2] (No such file or directory)
4 (2021-04-13 4:00:10:463363): [sss_cache] [init_domains] (0x0020): Could not initialize domains
Weird that this didn’t pop up right after installation ![]()
Well that’s where it gets fuzzy…
[tarulia@localhost]~% groups
tarulia wheel
[tarulia@localhost]~% cat /etc/group | grep mock
mock:x:135:tarulia
So uh… ??? This is also after newgrp -, so new groups should have applied already.
But even then it should just not doing anything instead of error out, right?
Either way, adding the group on that… same result:
[tarulia@localhost]~% usermod -aG mock mocktest
usermod: Permission denied.
usermod: cannot lock /etc/group; try again later.
[tarulia@localhost]~% sudo !!
sudo usermod -aG mock mocktest
(2021-04-13 18:33:32:480006): [sss_cache] [confdb_get_enabled_domain_list] (0x0040): Failed to get [domains] from [sssd], error [2] (No such file or directory)
(2021-04-13 18:33:32:480058): [sss_cache] [init_domains] (0x0020): Could not initialize domains
(2021-04-13 18:33:32:486763): [sss_cache] [confdb_get_enabled_domain_list] (0x0040): Failed to get [domains] from [sssd], error [2] (No such file or directory)
(2021-04-13 18:33:32:486810): [sss_cache] [init_domains] (0x0020): Could not initialize domains
Soooo something seems broken ![]()
edit:
Actually I do remember I had to install something LDAP related way back… The Blizzard Launcher needed some authentication library that is only provided by OpenLDAP, but I never configured anything on it… I wouldn’t have assumed it does much without configuration ![]()
But that was like 2 years ago at this point, never gave me issues but probably just never noticed.
I was actually thinking about a full re-install when F34 comes out (specially with them changing default filesystem too), so that might be one more reason to do it… I’m just worried it will mess up some things even more then they are (looking at my broken audio setup).
If it was already there when I installed OpenLDAP and I just never noticed or what…
