so i went back to gdisk…
and just decided to write again without changing anything…
Command (? for help): w
Warning! Secondary header is placed too early on the disk! Do you want to
correct this problem? (Y/N): y
Have moved second header and partition table to correct location.
Final checks complete. About to write GPT data. THIS WILL OVERWRITE EXISTING
PARTITIONS!!
Do you want to proceed? (Y/N): y
that fixed the issue… i was able to grow the partition afterwards…
GPT fdisk (gdisk) version 1.0.5
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/sdb: 1310720000 sectors, 625.0 GiB
Model: QEMU HARDDISK
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): 9CF54259-EF78-4238-A345-3402654C4D00
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 1310719966
Partitions will be aligned on 2048-sector boundaries
Total free space is 10485693 sectors (5.0 GiB)
Number Start (sector) End (sector) Size Code Name
1 2048 1300236287 620.0 GiB 8E00 Linux LVM
Any advice on how to force a group and mode to be used when a samba user creates a file or directory?
For example, you have appAdmin and tenanAdmin who are samba users. There is also a global_group. Both appAdmin and tenant admin are in globacl_group.
I’m not certain what I should use to make mode 775 and group permissions for all directories and files created by these users. Part of thinks it’s sticky bits another thinks its samba configs.
I know a few tools like rsync can sneak past and break it, I certainly haven’t tried it with Samba specifically… but Linux ACLs generally do what you want:
# Force newly created FOLDERS to inherit the same settings
setfacl -m d:g:$USER_GROUP:rwx,g:$USER_GROUP:rw,d:o::---,o::--- $FOLDER
Is there a way to enforce this behavior on subdirectories after they’ve been created?
In other words, after creating a folder structure can you set a sticky bit on a parent folder and have that propagate to the children folders, without deleting and recreating the folders?
I’ll check real quick, but I think that only sets the permissions correctly for newly created folders within the parent. I’m wondering if I can run a command like that and it update the folders that have already been created within the parent.
Assume I have already created the following directory tree:
However, now I need to set the sticky bit for the group from /cool/InnerCool/genericFolder down after the subFolders have been created.
I could issue:
chmod g+s /cool/InnerCool/genericFolder
However, that will not affect the current folders already created, which I need to update. I would prefer to not have to delete them and recreate them because that might be painful.
Is there anyway to organize the GNOME app drawer? (Sorry I don’t know a better word for it.) It’s a completely disorganized mess, and one of the reasons I dislike GNOME. But GNOME currently is the only stable desktop I can find on Fedora 33. XFCE and Cinammon keep crashing on me.
So are there any GNOME utilities/tweaks for managing this chaos?
Are you talking about grouping applications? If so, stock the intention is that you would type to search.
If you don’t mind using a menu system like Ms Windows 7 and prior, check the gnome extensions page. https://extensions.gnome.org/
I am on an MS Windows PC at work, but I believe the extension is called “Applications Menu” and is installed stock, but not turned on in the Tweaks menu. You can use gconf2 to organize things where you actually want them to be and ignore their meta tags.
