The quest for 8 threads continues
Previously on “Thread Wars”:
A New Thread:
The Adapter Strikes Back
And now, after long wait.
The Return of The Cores!
yes-yes-yes
Thanks again @KemoKa73
Praise be to @KemoKa73!
BTW, nice editing skills. That picture of the cooler looks awesome
Hahaha, thanks. 1st two are literally desaturate + zoom blur. 3rd one is bumped saturation + lens flare.
To my mild surprise GIMP does effects on 1 thread…
haha, that’s a bummer. All those threads, gone to waste.
Glad to see it working well! :smiley:
Yey! Mom, look, I finally won something!
#metoo Will do same small non-scientific benches I did on i5 to see get the feeling for it. Will post the results here.
So ehm… They’re seem like almost parity. I expected bit more from SMT I guess. And it seems in graphics it’s even bit worse. Need more games to test. (I don’t play a lot nowadays) It does feel more responsive (on Linux at least) when multitasking. (simulated rendering stuff in blender, watching anime and browsing interwebs)
TL:DR;
Shitty benches
System Config
Shared:
    MB: Gigabyte P75-D3
        Chipset: Intel B75
        BIOS: American Megatrends F9 08/21/2012 Rev. 4.6
    RAM: DDR3 24060 MiB                          XEON/i5
        Channel 0: 2x Hitachi GY1600D364L9/4G  @ 1333/1600 MHz
        Channel 1: 2x Hitachi GY1600D364L10/8G @ 1333/1600 MHz
    GPU: Sapphire Toxic Radeon R9 270X
        Chip: AMD Curacao XT GCN 1.0
        Freq: 1100 MHz w/ 1150 MHz Turbo
        VRAM: GDDR5 2048 MB
            BUS: 256bit
            CLK: 1500 MHz
        APIs:
            Shader Model: 5.1
            OpenGL:  4.5
            OpenCL:  1.2
            Vulkan:  1.0.0.1
            DirextX: 12.0
Arch:
    SSD: Samsung SSD 750 (232.9 GiB)
        FS:
            /     ext4
            /boot fat32
            /home ext4
    HDD: TOSHIBA DT01ACA2 (1.8 TiB)
        FS: /data ext4 (with 24 GiB swapfile)
    Kernel:     4.16.6-1-ARCH #1 SMP PREEMPT x86_64 GNU/Linux
    firmware:   intel-ucode 20180312-1
    DE/WM:      KDE/KWin plasma-desktop 5.12.5-1
    GPU Driver: xf86-video-amdgpu 18.0.1-1
    OpenGL:     mesa 18.0.2-1
    Vulkan:     vulkan-radeon 18.0.2-1
Windows 7:
    HDD: WDC WD5000AZRX-0 (456.8 GiB)
        FS:
            system   ???
            C:       ntfs
    Version: Ultimate SP 1
    GPU Driver: AMD Radeon 18.2.3
lscpu
SKU     | CPUs | T per C | MHz Max | MHz Min | BogoMIPS | Virt | $L1 (i, d) |   $L2  |   $L3
i5-3570 | 4    | 1       | 3800    | 1600    | 6787.47  | VT-x | 32K,  32K  |  256K  |  6144K
E3-1240 | 4    | 2       | 3700    | 1600    | 6587.19  | VT-x | 32K,  32K  |  256K  |  8192K
CS:GO 1.36.3.4 on Arch from SSD
1080p
max settings
V-SYNC: Double buffered, gets more than 60?!
CPU     | AVG FPS | Lowest (eyeballed)
i5-3570 | 144.38  | >= 30.0
E3-1240 | 136.50  | >= 30.0
CS:GO 1.36.3.4 on Windows 7
1080p
max settings
V-SYNC: Double buffered and Off, never gets more that 60?!
i5-3570 | 56.19   | >= 15.0
E3-1240 | 56.40   | >= 15.0
Blender 2.79b (BMW Bench version 1.0.7) on Arch
CPU     | Render time
i5-3570 | 0:03:24
E3-1240 | 0:02:49
Linux build form source on Arch
Sources: linux-4.16.7
Config:  make xconfig (default, open and save)
Timing:  perf stat -d
binutils: binutils 2.30-3
GCC:      gcc 7.3.1+20180406-1
CPU     | make | compile time
i5-3570 | -j4  | 292.841525565
E3-1240 | -j8  | 241.539696077
sysbench 1.0.14-155cd9d on Arch
sysbench cpu --cpu-max-prime=20000 --threads=THREADS run
where THREADS = CPU native threads (4 and 8)
CPU     | total time | events per second
i5-3570 |  10.0022s  | 1754.36
E3-1240 |  10.0024s  | 2373.30
sysbench memory --threads=THREADS run
block size: 1KiB
total size: 102400MiB
operation: write
scope: global
CPU     | total time | Total Ops | OPs/second  |  Transfered   |   Trans/second
i5-3570 |  8.6084s   | 104857600 | 12177983.15 | 102400.00 MiB | 11892.56 MiB/sec
E3-1240 |  6.1120s   | 104857600 | 17150725.00 | 102400.00 MiB | 16748.75 MiB/sec
7-Zip 16.04 on Windows 7
Dict. size: 32 MB
CPU thread: (4 or 8 depending on CPU)
CPU     | Elapsed time | Passes | Compression Rating | Decompression Rating | Total Rating
i5-3570 |   00:01:32   |   10   |     15404 MIPS     |     14690 MIPS       |  15047 MIPS
E3-1240 |   00:02:27   |   10   |     19069 MIPS     |     18862 MIPS       |  18971 MIPS
Cinebench R15.0 on Windows 7
Pure CPU
CPU     |  cb
i5-3570 | 511
E3-1240 | 599
OpenGL
CPU     |  FPS
i5-3570 | 90.58
E3-1240 | 85.83
Well, I have another LGA 1155 MB that currently house an i3 with really shitty cooling solution (Tech Cringe worthy), so I guess I’ll put my i5 there, when I buy better cooler for that.
Also, just a funny observation.
> swap CPUs
> boot into Linux
> Linux just worked as usual, just showing me more threads
> reboot into Win7
> “I am not even surprised, lol”
It also wanted a reboot ofc.
