Howdy folks! I figured I’d toss up a build log, since I’m addicted to buying AMD CPUs in recent years. If I had a wife to feed or kids to educate, this would be a serious problem! It appears that I have a fetish for buying AMD cores I don’t need or use, just to get some small measure of revenge on Intel for, well, just being Intel.
So I bought some X570 guts recently, and this forced the migration of my beloved Crosshair VII / 2700X combo out of my main rig, and relegated it to ‘backup rig’ status. Moving guts between systems is so easy for people who air cool. That must be nice. This is what a water coolers basement looks like when migrating guts also while having NO organizational skills whatsoever:
So this build, this backup rig, inadvertently turned out to be the nicest build I’ve ever put together, which prompted me to post it here. Since my backup rig has a Radeon VII GPU, it also became only my second all-AMD build ever, in 30 years of PC building. Another reason to post it on Level1, since everyone loves AMD here.
So I stripped the old rig and sold it to a buddy. He has two babies and not much money, since apparently those things are expensive. So he got a good deal. Oldie was a Crosshair VI / R7 1700. The starting point was this :
Apply motherboard, GPU, Barrow flow meter, and some 16mm acrylic tube (death to PETG, death!), along with 8 million dollars in fittings:
Fill it up with coolant, and have your masculinity threatened by a mere color:
I wanted purple, not “lavender”, and certainly not pink. Out came ye olde Feser blue dye:
Now THIS was more what I had in mind:
Tried to keep the tube neat and tidy, one bend only:
I originally got this mono block for the C6H, but it fit the C7H too. Bonus:
Pretty Purple Pixel Eater 2.0:
AMD Ryzen 2700x / Asus Crosshair VII motherboard
4 x 8GB G.Skill TridentZ RGB RAM (3200CL14)
Gigabyte Radeon VII GPU (2100mhz core, 1200mhz HBM, woot!)
Intel 600p 1TB NVME SSE
Thermaltake Core P3 Case
Corsair AX850i 850W PSU
Water Cooling Stuff:
EK Monoblock on motherboard
EK Vector GPU block
Alphacool NexXxoS UT60 Full Copper 360mm radiator - White Special Edition
3 x EK Vardar 140mm fans (white)
Singularity Computers 250mm reservoir with D5 pump (clear acrylic)
Barrow D5 dress cover (purple)
Barrow digital flow meter
Darkside G1/4" temp sensor
3 x 16MM EK hard tube fittings (purple)
8 x Darkside 90 degree fittings (white)
2 x Darkside 30mm extension fittings (white)
1 x Darkside 5mm extension fitting (because I’m too lazy to re-bend a tube)
1 x TFC SLI fitting
