The POWER and PowerPC General Discussion / News Thread
More than dead lol
@Mastic_Warrior
Interesting. Now that they are cheap, “GCC 10 Compiler Drops IBM Cell Broadband Engine SPU Support”.
https://www.phoronix.com/scan.php?page=news_item&px=GCC-10-Drops-Cell-BE-SPU
Gcc is trash use clang or die.
I am a GCCer. I have not tried LLVM/CLANG since 4.1 but man was it a pain to use.
If I am mistaken, I don’t think LLVM/CLANG has any optimizations for Cell BE. Sony used BSD for the OS, but they used their own modified version of GCC plugins to code and debug PSGL.
do you have anything to back that up, or is it just “some guy said that”
@q66
installed fine boot fails what do?
I think you need to rotate the computer 90 degrees counter-clockwise. I think it is low on CPU Oil.
i have a portrait monitor makes reading ez
There is your problem, as Lord Jobs would say, “… you are viewing it wrong!”
I’m half of a meme ignore me.
I just don’t like RMS :stuck_out_tongue:
dunno
there shouldn’t be much of a difference between live and actual boot, and live already comes with the latest kernel… the only thing i can think of is the hardening features enabled on kernel cmdline (page_poison and slub_debug), try editing the menu entry in grub and removing those
i can get other distros working in yaboot but i cant get yaboot to load in void
yaboot is dead, i don’t support yaboot, i won’t support yaboot
chances are it won’t even load ELFv2 kernels and stuff, and since it’s dead, there’s nothing that can be done about it
just use grub
time to learn
there really is nothing to learn, all you need is a sufficiently large bootstrap partition (i.e. not 800k, give it a few megabytes at least) and then grub-install /dev/sdXN where sdXN is your bootstrap partition
then you need to manually bless the right directory and stuff since grub-install does not do it by itself:
hmount /dev/sdXN
hattrib -t tbxi -c UNIX :System:Library:CoreServices:BootX
hattrib -b :System:Library:CoreServices
humount
The installer will do it all for you so you don’t even need to do any of this if you use that
I would like to note they are not on stock OFW, but rather updated to 2013 openBIOS.
@q66 its been fucky
spoofed the firmware update in osx with the best of my ablity ob to act as 5.1.5f2 it installed fine and osx worked fine linux is acting up
probably works the same, if it can boot OS X, it must work the same
though maybe it could be more of a SLOF style thing with a PReP boot partition, dunno (the installer supports that too, installation methods can be forced with like, PPC_FLAVOR=mac, PPC_FLAVOR=chrp, PPC_FLAVOR=opal on environment when autodetection fails)
thats… interesting. Where to look up SLOF docs?
Edit: NVM SLOF is on github. Never knew!
