This is a crude build only I've used as a daily driver for the living room. FlexATX power supplies have space-saving advantages over SFX, and you can pretty much get a PC down to a size comparable console.
This thing has been stuck in time, so I'm willing to trade/sell CPU & Mobo.
Current Specs (willing to sell/trade):
i5 2500k
4GB DDR3
GA-Z77N-WIFI
GTX 650 ti
600gb Velociraptor
500w Athena FlexATX PSU
Looking to upgrade to FX 8370E and a GTX 950 when it comes out or a GTX 960. Rather get the 960 because I'd really like to know how much this little PSU can deliver. I've been using it as a daily driver and it has been killer.
Putting it together
modified the original case to fit a silent centri-fan
rigged a remote switch, which is actually pretty effective
Removed the first 2 sata leads altogether and added a floppy power cable for slim drive, molex for fans, left the sata for HDD, in that order
added power leads from the 24-pin connector so the remote switch always functions
FATX power supplies have space-saving advantages over SFX, and you can pretty much get a PC down to a size comparable console.
