ThatGuyB's rants
What i ment. I see investing in a company buying hardware. making a company grow. The stock market is so abstract. And the money only go’s to the company when they release the stocks. The company also looses ownership over it self. Basicly the owners sell the company. The investing part is on the money the money is used to get a part of a company. This investment is not in the company. But in the wealth of the person buying the share.
Companies that release too much stock open themselves up to being bought out by investment management groups that replace board members to squeeze more profits for shareholders. Intel has gotten themselves into that situation as Qualcomm and others are eying buying them to spin everything off and keep the CPU development to themselves(Qualcomm dispute with ARM is an example of this reason of eating Intel). Intel pushed the QA to its limits by 3rd party influence(investment groups pushing it) and that is why 13th/14th gen over-voltage has made them attractive to be bought and split up.
I’m waiting for the AI bubble to pop like the dotcom era, all those companies buying globs of GPUs as more CPUs use an IGP/NPU to trim the power usage for basic AI tasks. Apple ditching the future development of the Vision Pro 2.0 is a sign like Meta’s “pro VR”.
I get how the stock market works. What i mean to say it creates not healthy company’s. A good example is I don’t know the company’s name But it sels Ice tea cheap in America. Wel that is an example of a well run healthy company. Google Meta or for example Philips isn’t
Meta like Philips have been chasing or catching up by spending stupidly, Meta’s VR lagged behind every company. Apple jumped into the Meta failure.
As a lecture on financial matters once had a slide of “avoid companies of part-time CEOs”.
Philips didn’t invest anything anymore. There buisnes model past 30 years was selling of parts of the buisnes.
Meta wanted to grow more after they became bigger then Earth. well that wasn’t posible. Remember the riots in Egypt. Facebook literly controled the world. I think Mark suckerberg’s reminds me of Icarus
In a random test to shave off some watts, I tried running my 1440p 170Hz monitor at 60Hz. I decreased the power consumption from 102W to 97W, shaving off a whopping… 5W. Note that when the display was going black (to refresh sway’s .config), the power draw was falling to 83W. So it’s clear the monitor uses the most amount of power here.
Note: test above was with both monitors plugged in and with my small SSD NAS powered on, switch and rockpro64 router).
If I only run my portable monitor, my power draw is 63W (so just powering off my large monitor and its speakers). I’m really happy with the large (and high refresh rate) monitor, but I’m really not happy about it consuming more than my actual PC (FFS). Even the 5-10W that the portable monitor uses is a bit hard to swallow (1080p 60Hz USB powered with touchscreen that I don’t use) for my use case (basically static pages 95% of the time.
I was thinking of getting an e-paper 1080p (or higher) display, to lower the consumption to less than 1W. But the price is a bit difficult to digest ($500+ for 1080p, upwards of $1200).
I noticed this for a while, but I kept forgetting about it. My 12 port switch (8x 1Gbps, 2x 2.5G, 2x SFP+) keeps restarting itself at random times. Today more than usual. The 120W PSU isn’t the problem itself, because the switch restarts when only the PC and portable monitor are powered on.
That leads to the conclusion that the USB type-C brick is not providing the switch enough juice to keep running. Previously, when I only had my gigabit router and 2.5G port connected to my PC, it was doing alright. Now, when I have both my PC and my NAS @ 2.5G and the router connected, it started restarting more frequently.
The 130W usb type-c (12v cigarette) barrel has 3 ports: 100W (C), 30W (C) and 18W (A) (IIRC). When all 3 ports are connected, it goes 60W, 15W, 15W. I only have 2 connected, so it should be giving ~90W to the PC and 30W to the switch. The switch had a 12v 1.5A (18W) brick from the factory.
The PC connected on the same cigarette barrel doesn’t restart, but the switch does. The only other thing that could be the issue, would be the USB cable or the type-c to 12V 5521 adapter. I’m using the same cable (but a 15v adapter) with my PC and the same cable and same 12v adapter with other devices and I don’t have this issue. I refuse to believe it’s the switch, particularly when it restarts 2 or 3 times in a row, then works just fine. The cigarette barrel seems to have enough juice to feed the switch and PC (another 1 is feeding the more hungry 170hz monitor and the speakers, although that’s only using 1 port @ 120W at 20v usb power delivery).
I should attempt to power the switch individually and try to reproduce the issue, but given that it’s random, reproducibility goes out the window. This should just serve as a reminder for myself to do it.
After 3 more random restarts in 1 hour after I posted the above, I got mad and changed the USB port for the switch, to have its own dedicated barrel. Technically the output will only go to up 36W (12V 3A), but still it’s double what its original brick’s output was and about 6W more than what the type c port 2 on the shared brick offered.
At this point, if I notice any more restarts I’ll be really pissed.
Each female cigarette socket has a 10A fuse, meaning the most I can draw from a single socket is 120W (about the same as each USB C PD barrel). I’m basically guaranteed I’ll never reach those draws with the current configuration (the barrels themselves have over-current and over-voltage protection and some temperature control to shut themselves off when it gets too hot). Each socket is individually controlled via a switch (which is rated for 12v 50A, which is way overkill, but that’s all I could find).
I was thinking of changing my setup to have a larger fuse (corresponding to however much the wires will be able to transport and the expected power draw), a bus-bar and wire everything to a couple of buck-boost converter, corresponding to each voltages I need (12, 15 and 19v). Unfortunately that would mean no more fancy usb type-c wires, but I’d be getting custom lengths (so keeping rats nests in check).
Over the last couple of days I’ve been fighting to resurrect my old toshiba encore. It’s been working alright for the past year, but in the last month or so, when trying to update the system, I’d get really low download throughput (4 KB/s). I thought it might be the network, but eventually, after my /boot filled up with old initramfs images (oops, my bad), the system wouldn’t boot up on the latest one.
From there, I just booted into the previous working one, cleaned the old stuff and regenerated a new initramfs. Well, that didn’t work out, as the boot was still failing. Eventually waited for some new kernel updates to come in and after an update… the dreaded I/O error. I knew this was a sign that the internal emmc was about to die.
To prolong its life, I wanted to try out booting postmarketos from a microSD card. That didn’t work out, as the image seemed to be burned with a MBR partition table. Still, it should’ve booted if I tried from GRUB on the emmc. I tried to install os-prober and… I/O error.
Frustration levels were pretty high. I tried to reinstall my main OS on a smaller partition, to try to avoid the corrupted flash blocks. I made it 8GB (out of 32). Still failed to update after the initial install. I then installed the OS on the microSD card and the boot partition on emmc. The system wouldn’t boot (something about missing initramfs, which shouldn’t be the case, but it seemed it was still getting the old boot entries).
I wiped the whole emmc clean of any old partitions, reinstalled and I managed to boot from emmc with rootfs on sd. Upgrade took long and eventually I got an I/O error again, this time for the microSD card. It’s a brand new 256GB card partitioned for only 64GB (I thought it might be ok to overprovision it). Well, I completely forgot the SD controller on my tablet is an absolute pile of burning trash. It was always getting disconnected in windows under high I/O loads. Now with linux on it, I was surprised I didn’t get a kernel panic for unmounted root, but despite the I/O error, the root partition stayed mounted and accessible.
The last thing remaining is unfortunately to run the OS off of a USB SSD, meaning that portability goes out the window (reminder that this is an x86_64 tablet). To be fair, I wasn’t really carrying this around (due to running a 10 y.o. battery), but it was nice to have that ability.
Since I wasn’t able to ever get the internal BT chip to work with my keyboard, I always used a USB dongle with it and the tablet was always charging while in use (and unplugged when shut off). But now I’d have to power a USB SSD and the tablet. And I’d be limited to the usb 2.0 interface (480 Mbps). To be fair, I wouldn’t really need much I/O performance, this is just a glorified touchscreen netbook.
But what I’m worried about is that the tablet might actually discharge faster than it charges. Even with a 3A USB PSU (its original one was only a 2A brick), if I was using the CPU and GPU a lot, it would discharge from 100% to around 51%, then when it dropped below that, it would freeze (I can only assume the power provided wasn’t enough for the CPU to boost, despite it being presented as “charging” and it just froze - I can’t exactly see /var/log/messages or dmesg when the only thing I can do with it is force off).
Now if I introduce a USB SSD, I think I might need a beefier PSU. Unfortunately even when I had an externally powered USB hub, the tablet would still discharge. Even if I use my adapter that completely cuts the power off from the USB port and only data goes in (power comes from another USB brick), the tablet still manages to discharge. I can only assume that either the CPU is too power hungry or that the USB controller draws too much juice.
I can’t say what would happen now if I don’t use the internal EMMC at all and do everything off of USB, but I doubt it’d be enough to really off-shift the power usage. Wish me luck, 'cuz I’m going to try that anyway.
Ok, so before I tried that, I wanted to check if running the same SD card on a USB controller worked. That did work to update the system and install some software. But the weird 8 KB/s throughput thing still occurred. I’m not sure what could be the reason. It could be the wifi chip or it could be something else. One thing’s for sure, even with the OS on a nvme SSD on a powered USB hub, I still get the weird low throughput update behavior.
No I/O errors this time, just really slow download speeds. I’m super bummed that this slow download speed might be a separate issue. But given that both the nvme ssd and the sd card behave the same, I can rule out some things. The repo is not it, because switching repos has the same behavior.
I can get faster speeds when I first download things from the repo, but after a minute, it goes down. Getting near or farther from the AP doesn’t seem to change anything. I tried a USB ethernet adapter and I get more consistent good results, but still get a huge drop in throughput for large files and drops to about 78 KB/s (average is a decent 1.4 MB/s, which I’m happy with, but again it’s on wire).
It might be time to say bye to the tablet. I’m going to attempt to run the OS solely from SD cards (for the lower power draw) and see if I can prolong its lifetime. If not, I’ll use my portable monitor with my old pi 4 (15.6" vs 8").
I really dig the L1T MIIR bottle (store.level1techs.com). It holds about 2.5x cups (not measuring cups) of tea and I can pressure infuse tea into it (at lower temps, almost ready to drink).
I don’t drink straight from it, but I like the fact that it’s all metal and that if you were to drink from it, your mouth wouldn’t be touching plastic. The rubber seal and plastic lid are a bit unfortunate, but it’d be difficult to make a tight seal out of other materials (and make them last as long and not decompose after 2 weeks - maybe cork held down with a metal clamp?). I don’t take it with me outside the house, but I suppose I’d be a minority (well, idk how many people on this forum are getting out of their houses for things other than work or shopping, but I mean people in general - normies).
It doesn’t keep things warm overnight, but it’s not advertised as such. I’d like to make my own thermally-insulated bottle, out of a normal glass bottle, with either a metal screw or a cork and have it insulated on the outside with (maybe toxic) materials (it’s fine as long as it doesn’t come into contact with the contents of the glass bottle). It would be cool to make a solid vacuum around the bottle, but that’d be unrealistic (and I’m afraid of the outwards / pulling pressure the glass bottle would be exposed to).
IDK what else to say. It’s a good bottle.
:man_shrugging:
There is an old thread on the Pi forums that list consumer grade SD cards that get close to endurance models. Cheaper to still offload swap to a flash drive to cut fail rates.
Cooling loops you could generate electric turbine using passive fluid such as laundry and toilet like those shower lights that use friction to turn on a LED. 4 magnets you can get 45W that gets respun from daily tasks.
Fairly easy to push 500-800W via scaling to the size of an A4 Skyhawk engine if you move to titanium :thinking:
I’m not sure which part you’re replying to, lmao!
I’m more inclined to do root-on-nfs (diskless installs) and for things that don’t work on NFS for whatever reason (like incus, idk why), attach an iscsi lun and properly automate it in the service supervision. I still bought some SD cards for testing some things, but they’ll probably be temporary.
These don’t give you enough power. The shower or sink lights are a cool gimmick (particularly the ones that change based on the temperature of the water), but they don’t generate enough power constantly.
Solar should generate enough for most usage, but I want to have a backup for most critical consumers. I’ll need to get a wind measuring apparatus, to see how much wind I’ll get where I’ll move to and if I get decent wind on the roof, then I can build a small tower (higher altitude means more wind) for a (vertical) wind turbine. If I can get 100 W/h during short or rainy days from a 500W wind power generator, it’s probably worth it for me (if I’ll get 1200Wh / day from wind, when I’m not getting enough from solar, that should be enough).
But I’m looking into no-energy (or close to none) alternatives (e.g. fridge0). The biggest consumer would probably be an incinerating toiler, which I really don’t know what I’ll do to power it off-grid electrically (not the propane versions). I’d love to have a composting toilet, but many places around prohibit them.
Scale this this concept and it does produce lots of stability and no need for solar panels if you can get it stable to peak 800W:
Design it to handle 670 MPH and its inside the form factor of a Pratt & Whitney J52-P-408A
The weirdest thing happened to me today. I made a new user profile on my vanilla android phone and after a couple of minutes of customizing and what-not, I woke up with TikTok, Temu and other bulls**t on my phone. I saw the “MCM Client” running in the notifications.
I got out of the user, wiped it and created it fresh. As soon as I did, I went through the setup process and once I got out of it, immediately disabled “MCM Client” and “Mobile Installer.” It’s insane that there’s an option in stock phones to allow whoever (carriers or OEMs) to automatically push malware to your phone. Nobody asked me if I want to install crap. This is absolutely f**king ridiculous!
Wasn’t Microsoft sued by the EU or something for this exact behavior (getting paid to installing Candy Crush on Windows 10)? How do phone manufacturers and / or carriers get away with the same BS?
I’m buying a new device and will immediately install a degoogled OS on it. I’ll probably wipe my phone too, once I’m done with it and install lineage or something on it. Freaking unreal!
Model? Quite common on Samsung models, some Moto models in US also seems to at least install Tiktok and of course the chinese stuff like Xiaomi etc.
Motorola moto g stylus 5G carrier-locked in Metro in the US. IDK if plain unlocked ones behave the same.
I bought the phone with the money down, idk why it was locked with them to begin with. I requested the unlock a long time ago, idk if that went through. I’ll be looking into that again, update it to the latest firmware and then wipe it clean for lineageos.
It seems like the US models/firmware is more “prone” to this kind of stuff but it’s only optional as far as I can tell? That being said, not sure if it’s worth spending too much time on a phone sporting the now rather old Snapdragon 480 so it should be like 3+ years old now and pretty sluggish.
If you’re looking for a value phone CMF Phone 1 by Nothing or Nothing Phone 2a might be of interest and I think those are available in NA too at least from Nothing.
I believe it is. It still had some firmware updates recently (like a month or 2 ago IIRC).
Not in the slightest, but I see problems with memory utilization (sometimes apps crash when multitasking, unless I reboot my phone and perform everything fresh ASAP).
I’m not even looking for a phone. I’m tempted to buy the PinePhone Pro, because it’s decently fast for what I need and I can run it as my daily driver if I connect a display to it. I already carry a hotspot with me if I know I need internet, so might as well use that as a pocket PC (I don’t even take phone calls or SMS). My phone is a glorified messenger anyway (I don’t look at my phone on-the-go except for maps).
IDK what black magic void pulls off, but my old toshiba encore is really buggy and barely works with anything. Initially there’s been some bugs while upgrading. It’s been running fine for a long time, but since 2 months ago or so it’s been upgrading at very slow speeds, something like 22KB/s.
Initially I thought it might’ve been the emmc flash dying. dmesg wasn’t reporting any I/O error about that, but xbps upgrade was getting i/o error here and there (aside from the slow speed). So I switched to install void on a uSD card and I encountered the same bug with <30KB/s download speed. The original encore has been known to have a cheap and crappy microsd slot, so I thought “hey, maybe it’s just the controller” (I’ve had issues with SD cards not getting recognized in windows over 10 years ago when the tablet was brand new; the card was fine, but windows would block out - and to avoid card corruption, I’d have to power it off gracefully, remove the sd, power it on and then plug the sd back, which was an absolute pain).
So after a long time of procrastination, I ordered a microSD usb reader and today installed void… and the same thing happened: really low xbps upgrade performance. It’s not the wifi, because sometimes it works 'till the end, other times it give i/o error (brand new sd cards as well, tried 2 of them).
So I thought it might just be a baytrail atom bug (it’s known to be buggy). I went through old forum posts and enabled “intel_idle.max_cstate=1” in /etc/default/grub, but that didn’t do anything. I later read that the setting isn’t needed past some patch in kernel 4.9 and 5.1 (I was running 6.1 and was trying to upgrade to 6.12, but the upgrade process was slow).
So I thought it might be time to install something else on it and see what happens. And this brings me to the “black magic” mentioned at the beginning of the rant. I tried artix and devuan and neither manage to boot on it. Artix didn’t even boot from USB, while devuan booted and installed, but wouldn’t boot past installation. It had both a grubx64.efi and grubia32.efi files, but the tablet wouldn’t recognize it (and the firmware doesn’t allow to browse for efi files manually, 'cuz crappy tablet uefi).
I think I’m reaching the limit of my patience. I know the tablet is still good enough for what I need it to do for me (basically a glorified browser), but I’m not willing to waste so much time on fixing it anymore. I might try lmde xfce and maybe mx linux and then call it quits.
If I’ll fail to make this work, I’ll make my pi 4 my bed-side PC (the bcm2711 might actually be faster than the atom z3740 anyway, not to mention having 4x the RAM).
