Ever since the ambassador having a full crit update around may 28th, when I play TF2 my computer randomly freezes and plays the last 2 seconds of gameplay over n over again and I have to do a hard reboot.. this be bad for my computer but I don't want to stop playing Tf2. The problem doesn't happen when I play any other game like killing floor or crysis, so why tf2? Logan said its a problem with the update.. Any Suggestions?
This is Master Apple, I forgot to sign out of logan's thingy when he was over.
Wel you could wait for a next update to see if they fix anything, or you could try to reinstall the game. I havent had a problem with the new update for the ambassador yet. Played yesterday and got killed a several times by it, so I dont know...
Heres a picture of the graphic jumble. According to my friend : This isn't what happens when you overclock. This is what happens when the game engine stops playing nicely with your video card. Note there's no artifacting or anything indicative of heat. It's just textures being mapped improperly all over the place.
Firstly, I'd recommend doing a re-verify of the TF2 files. If that doesn't fix it, update your drivers (make absolutely sure they're the latest ones).
EDIT 1 : Crashes came back. Someone said stop playing Tf2 or my GPU will get messed up ]:
