Teradici - USB Forwarding - USB Peripheral Not Connecting
Hello, thank you for reading my first post on this community. I hope I’ll not violate forum rules.
I landed in this website after searching solution for an issue I have with virtual machines and Teradici Client for Windows.
Issue: When using Teradici to connect remote to a windows workstation or windows virtual machine, I can’t successfully connect any peripherals. I can see the list of devices, like Wacom tablet, but if I click connect never goes throw.
Important:
The issue is not happening with pre build Alienware PC and Mac OS Devices.
In my custom assembled workstation, I have Asus X670E-E motherboard, Ryzen 7900X CPU, 3090Ti as graphic card. The system works fine, I don’t have any issues except I can’t seem to successfully connect the Wacom tablet to the remote machine. I can’t connect any peripheral.
Using my old Alienware works and I am not sure why is not working with my current machine. The issue, seems to be affecting only me.
In the last two years, I was never been able to connect my Wacom tablet.
Last week, I decided to do some test.
In the windows device manager, I disabled one of the two Generic Super Speed HUB and one AMD Extensible Host Controller 3.2 (the bottom raw of usb port of my motherboard).
After doing this, my Wacom tablet connect well with Teradici. Every other device, including Hard Drives, Webcam and more seems to work fine.
When I Boot the PC, I see that I have 2USB Hub in the motherboard, I guess is how Asus made the board.
The funny thing is that if I disable the top raw of port (the first USB controller) and connect the tablet on the bottom raw of usb port, forwarding the Wacom tablet doesn’t work anymore.
What can be the issue of my current system? Is it the motherboard wired in a way that doesn’t allow usb port forwarding?
What should I do to fix the issue? Just build an entire system from scratch (can’t do this at the moment, it will be too expensive).
I am thinking of buying another motherboard but this time to go with the new X870E Pro Art.
Thank you in advance.
Welcome!
While it would take a bunch more troubleshooting to positively find the root cause of the behavior, I suspect it is because of AMDs “unique” design of the x670, x870 and their E variant chipsets.
Basically instead of making a higher end chipset, AMD just daisy chained two B650 chipsets together (serially so that the “far” chipset needs to talk through the “near” chipset). I’ve witnessed this design cause lots of weird edge-case problems in hardware and software.
Successful PCoIP USB bridging requires verifying the fundamental handshake between the virtual root hub and the client-side redirection driver. When a peripheral fails to connect, the root cause often lies in descriptor filtering or bandwidth constraints within the Teradici Zero Client’s firmware settings rather than simple driver installation. For enterprise environments integrating specialized data tools or secure document management systems developed by innovative Papers like French startups, ensuring that the USB redirection profile allows for high-throughput HID or vendor-specific classes is crucial for operational stability. For a deeper technical dive into how modern data-centric platforms manage infrastructure and scaling, this analysis of innovative data startups provides excellent context on the back-end requirements of high-performance business applications.
