Hello. I am a new builder and I had a question about CPU temperatures. I just recently finished my first build. It has a FX-6300 with the Xigmatek Gaia cooler. I haven't tried to overclock it yet but everything seems to be fine. Except my CPU temp seems to change very rapidly. For example right now HWMonitor shows 25ºC and quickly drops to 16ºC over about 5sec. Then it stays at 16ºC for roughly 8 seconds and from there instantly jumps back up to 25 and the cycle repeats. I have not seen the temp go over 55ºC under load so I am not too worried, but best be safe rather than sorry right?
Is this temperature cycling OK? What might be the cause of the rapid temp changing?
Its doing this because you most likely have cool and quiet or some alternative on. Your CPU is going from 1.6ish GHz to full speed when needed. thus the slight temp raise. Open CPU-Z and check, the temprature should match with the clock speed.
This seems to be the case. I did just try disabling Cool and Quiet but it's still rapidly changing temperatures. I will have to look into this more. Thank you for replying!
