I just want to boost the population and popularity of this relatively small section of the Tek Syndicate forum. I just feel that too many people in the United States have no idea what good coffee and tea taste like, and with the prevalence of coffee and tea-like beverages at all of the fast food restaurants, I wanted to create a forum post where people can provide their tea and coffee experiences, preparation methods, favorite blends or varieties and the best local places to find or taste these products.
if you just want to follow my tea reviews, I've made a separate website as a journal here: http://mndless.weebly.com
Now because I know people on Tek Syndicate forums like to provide insubstantial comments, I do want to provide a set of guidelines for how these posts should go.
Experiences: Try to describe in detail what happened. For many people, significant experiences with tea and coffee occur when they first try a certain type of beverage, or when they succeed in preparing something properly themselves.
favorite blends or products:
- Name of product
- Place of acquisition (if applicable or available)
- Picture (I love seeing what these things look like. If possible, I would love for people to post pictures of what the product is, or just what it looks like once prepared.)
- A thorough description of the experience with the product. For blends of coffee or tea: what does it look like, what does it smell like, taste like? How did you prepare it and did you have any difficulties?
So, the best way to make tea in a cast iron teapot is to start with some water. Fresh from the tap if you have good clean tasting soft water. If you have hard water, you might want to use a filter. If you have a pitcher-style filter, make a fresh pitcher of water for each batch. I, personally, use a filter that attaches to my faucet. The reasoning behind this is because you want freshly aerated water. Stagnate water has low levels of dissolved oxygen and tastes very flat. On top of that, it has difficulty dissolving some of the soluble compounds from the tea. So freshly drawn water.
Concerning the temperature of the water now. For black teas and maté and pu-erh you should use water that is at or very close to a boil. I like to take it off when you have readily forming pea sized bubbles, this gets you about 205-210 degrees throughout the pot. For white and green teas you should be at no more than 180 degrees, so very fine bubbles should be forming and rising to the surface like champagne. Oolong takes about 190 to 200 degrees, depending on the level of oxidation. Now for proper pot preparation. Once the water has come to temperature, pour about half a cups worth into the bottom of the pot and swirl it around to coat the bottom and sides of the pot. put your hands on the sides of the pot. When the pot feels nice and warm, it is ready for you to add tea. Now, as to the importance of warming the pot: proper tea extraction. You want the water to stay at the ideal extraction temperature for the entire duration of the steeping time. If you were to pour your water into a cold pot with your tea, the pot would steal so much heat from the water that your tea would be weak and flavorless. Pour out the water that you used to warm the pot and measure out your tea.
When doling out the loose leaf tea, it is typically recommended to use a full heaping teaspoon of leaves per 6 to 8 ounces of water, then another for the pot. My preferred measuring method is to dip out a full teaspoon and give it a little shake to knock off some of the loose leaves. Whatever stays goes into the pot.
Steeping times vary, and most brands are more than happy to give you recommendations for them. My rule of thumb is to let white and green teas steep for between one and a half and three minutes, oolong should absolutely be no more than three and a half minutes and most black teas can be steeped up to five minutes, depending on the preparation and flavor desired. Other teas like pu-erh and herbal infusions as well as matcha and maté are different stories. Maté can be steeped for in excess of five minutes, pu-erh for as little as thirty seconds and matcha may be mixed and consumed almost immediately.
On to the subject of straining. Do not use the included tea holders with teapots. Ever. They do not allow the proper room for the tea to bloom. Do not use teapots that have holes punched through to the spout to try to catch the tea leaves. These do not work and they are practically impossible to clean. In most cases, cast iron or glass pots lack these to begin with, so it isn't an issue. I like using a portafilter fitted either with a standard paper coffee filter or a very fine stainless steel or gold plated mesh. I have one that I got from an old and useless boiler-style espresso machine. It came with a fine mesh insert and a claim to make drip coffee as well as espresso. It did neither well, but I got a carafe and a portafilter from it, so I've got that going for me. Anyway. Strain the tea out of the liquid as you pour. you may also look for what is often called a pot skimmer or you could use a single cup coffee strainer.
If you intend to leave tea sitting in the pot for an extended amount of time, you should consider getting a warming pot to place the strained liquor in to, such as those sold by Teavana. These are typically made out of glass and feature an extended base designed to sit within a wooden cradle over a candle or alcohol flame. It is preferred to store tea in this manner as leaving the liquid in the pot with the leaves will only over-extract them and leave you with a bitter liquor.
As for serving, I prefer glass over china or ceramic, as I prefer the appearance. The main reason why you will not typically see people drink fine tea from metal cups is because the cups will add their own metallic flavor to the tea. Some brands will coat the metal in enamel inside to prevent this, but it has the possibility of chipping or cracking with use. Double-walled glass cups from Bodum are fairly easy to find and work fantastically well for tea as they add no flavor, are quite durable and allow you to see the beautiful color and clarity of properly steeped tea. In many tea ceremonies, the cups are warmed along with the teapot. This doesn't necessarily serve much of a purpose, unless you want to try to keep your tea warm as long as possible. Even so, it doesn't help very much.
Other things to know about tea: some flavoring agents commonly used with tea may create a cloudy liquor, these are typically your spices such as cinnamon and pepper. Most teas, when properly extracted, have very high clarity. Since I commonly drink mine from a high-ball glass, I will hold it up to a piece of text and try to read through it. If I can, then I know it is not over-extracted.
The other thing to note: black teas are not all dark when steeped. I find that people try too hard to reach this ideal of blackness with their liquor, and it doesn't bode well for the flavor of the tea. Some teas, such as Earl Grey, have very light red-orange liquors, while some English Breakfast blends may be a very dark reddish brown. Some green teas are yellow when steeped, some are almost as dark as black tea, and some are actually green. Oolong is a peculiarity as it can be a beautiful dusky red or it can be a pale golden-brown color. Pu-erh is almost always a beautifully deep warm brown, with hints of red and purple in the liquor.
