I’m also looking into this for my m4 max.
I have an OWC dock at work that is TB3, it was cheap and works… mostly.
In terms of things to AVOID:
I can confirm: be very careful about buying a PC thunderbolt dock. Some of them support multiple monitors but not in the way that macOS expects to.
Basically Windows supports MST for multi-stream-transport (multiple monitors over one connection), while macOS does not. So keep that in mind. MST looks like ass anyway due to compression.
I suspect for multiple monitors, you may need to either be careful with your dock purchase, or use a second thunderbolt output on your mac.
Additionally:
i’d avoid DisplayLink docks. they will certainly do multiple displays but:
- require install of a third party driver
- act like a virtual display adapter
- image quality is less due to compression and processing by the dock itself
I’ve used one, they work, but it pissed me off. Sometimes OS upgrades broke the driver, the driver needs security permissions i didn’t want to give it, and the colours/screen definition was… bad
Right now, i have a dock at work with one external display, and at home am using only one of my two external displays via direct USB-C connection. I am also looking for a dock to drive two displays.
edit:
I just asked claude, and it came up with some options that are supposedly confirmed to NOT use displaylink or MST
— snip—-
Recommended Docks
Thunderbolt 4 Options:
1. Plugable TBT4-UDZ (16-in-1)
∙ 2x HDMI 2.0 + 2x DisplayPort 1.2 outputs
∙ Explicitly supports dual 4K@60Hz on M4 Max
∙ 100W charging, 2.5Gbps Ethernet
∙ ~$299
1. CalDigit TS4
∙ Dual 4K@60Hz support (or single 6K)
∙ Industry standard, well-regarded
∙ 98W charging
∙ ~$399
1. Cable Matters 16-in-1 TB4
∙ 2x DisplayPort 1.4 + 2x HDMI 2.1
∙ Confirmed M4 Pro/Max support
∙ 100W charging
∙ ~$300
Thunderbolt 5 Option:
Kensington SD5000T5 EQ
∙ Supports dual 6K@60Hz on M4 Max (so dual 4K is easy)
∙ Future-proof with TB5 bandwidth (80Gbps)
∙ Premium option
Why This Works on Mac
Unlike Windows systems that often use MST for multi-monitor setups, Apple M1/M2/M3/M4 Pro/Max based Macs do not support DisplayPort MST (Multi-Stream Transport) technology and thus can support up to 2x 4K (3840x2160) 60Hz extended displays via 2x HDMI 2.0 and 2x DisplayPort 1.2 video outputs which can be connected in any combination of HDMI + HDMI, DP + DP, or a mix of HDMI + DP on proper Thunderbolt docks.
The M4 Max natively supports up to 4 external displays total, so using 2 from a dock is well within its capabilities.
— end of claude output —
What you’re looking for is DP alt-mode.
As always, check the output above, but claude seems confident that none of those are MST or DisplayLink!
