Less proprietary and a bit easier to use imo
Yes, plex will see it as being on the same network. Being anywhere, connected to tailscale, is just like being at home.
If you don’t have any services or connectivity needed for your non-tech family, then why look at a VPN solution?
I found I could only last a week or two on NextDNS before hitting their limit and had to set up a couple of pihole VMs… Do I just have a ridiculous number of DNS requests or have you hit that wall as well?
That’s odd. I usually do over 1.5M queries in a 30 day period and never been limited. I coughed up for their Pro plan as I easily burn through 300K queries in a month.
Might be worth checking out, I’m looking for a way to be able to access my server’s files when I’m out and about anyway…
Tailscale is amazing. I use their features like Tailscale lock, serve, funnel, certificates (integrates with caddy!) and the Mullvad integration. It’s so good I actually want to pay for it although the paid personal plan doesn’t have anything I actually find useful. I would in a heartbeat if they include stuff like using your own domain.
The only con I find is that if you build your stuff based on Tailscale and the internet fails down goes your talent too even if you need to talk with peers on your local network. I think it happened with Chris from Jupiter Broadcast when he took his RV to a remote area.
One suggestion would be:
- allow a peer to be a temporary satellite coordinator of sorts, in case the tailscale servers aren’t reachable.
also:
- make it easier to use own domain, including funnel. Bye bye Cloudflare!
I know it’s a bit rude to go off-topic but have a question about the forum:
How can you make these chapter markers with headlines next to the scroll bar in the very first posting of a thread?
Would like to learn that to use it in my own tpoics, too.
Condensed? SubscribeStar when?
No problem
you just add in this line anywhere in your post:
<div data-theme-toc="true"> </div>
@wendell @Level1_Amber @kreestuh
Awesome content i love when people discuss the problems, how they solved them and why
I really need to dig more into this cuz tailscale is super cool. Id love to not feel like its magic and actually understand it
Though I do wish there was a totally self hostable option
This is true for any VPN server or peer you run. You can do the same with wireguard, openvpn, and I believe an ssh tunnel too. Tailscale does make this functionality much more accessible and easy to use.
Internally it would look like your tailscale peers are using your IP though, so anything they mess up will point to you!
It won’t have any more permissions than your device at the office though. That’s why internal network security is important too. Anyone with an infected device on the network could e.g. bring ransomware in that can affect any network storage in a company.
Rolling your own wireguard comes pretty close, I would say? Unless I’m missing something. It will be more work.
edit: I do love their transparency:
Hi @PhaseLockedLoop, I have heard there is a totally self-hostable option called head Tails, which is a fork, I believe, of the Tails Scale.
Lawrence System mentioned Head Scale in a recent video.
@PhaseLockedLoop I found this video from Lawrence Systems that explains how to set up Head Scale as a self-hosted system. I think this is what you wanted.
The only downside i’ve found is the battery usage on phones.
Other than that for homelab use it’s amazing ![]()
I’ve just setup tailscale + sunshine + moonlight on an Arch gaming vm (with passthu GPU) and my tablet and phone. A plain old wireguard solution was causing me a lot of issues, this solution just works everywhere I’ve tried it but it was the simplicity of setup that really was the icing on the cake.
I used headscale before tailscale, it worked similarly at the time HOWEVER no mobile apps because sideloading is a PITA. have to have a real developer cert. which wasnt a problem for me but ehhh
Well thats a major deal breaker right there
If I moved my stuff in tailscale and then had to manage that for friends and fam. Nah Id rather pay the creator. He has done some awesome work
Tried and it just works as advertised, so far I am loving it.
This was a great video. I’ve been using Tailscale for quite some time and really like it. It “just works”, uses P2P encryption (via WG), and has a generous free tier of 100 devices.
On a $25 SBC I see over 500Mbps throughput on Tailscale P2P. That doesn’t seem amazing given the SBC can hit 900Mbps without the Tailscale overhead, but it makes an amazing device I can deploy to networks of family members and they can access my Jellyfin etc. without me needing to expose those services to the internet, even for their TVs which can’t run Tailscale natively.
As a bonus, I’ve learned a lot from reading their blog where they discuss various networking techniques including all the various NAT punching mechanisms.
Yes it’s the ease of it that makes this so crazy to me. I used to have Pritunl set up (ovpn) and getting subnet routing working only ever worked on a linux client with manually editing the config and setting up bridging. It was such a hassle that I resorted to an SSH tunnel to bypass it.
This just worked without any config on site.
I feel certain enough for our guest network, but our BYOD security can be better.
@wendell, I forgot to mention that I have only heard of Head Scale and have not had the time to look into It. I figured there would be no mobile app support, but since I would never use Head Scale on my tablet or phone, I don’t think no mobile app support is really a drawback. Could you explain what a real developer cert is and how I get one?
