Anyone know of any tablet with qi charging? Trying to do smart home hub and like the idea of being able to take it off the wall easily and not having a usb adapter for qi charging on it.
I’ve never seen one. What some manufacturer have done is using pogo pins and docks for tablets.
I think your best bet is to get whatever tablet, slap a USB wireless charging coil to it and be done with it.
Or you could DIY something with pogo pins or a USB C from a Nintendo Switch dock (the USB C on that dock is smaller so it plugs “frictionless”).
Yeah wasn’t having any luck on searching but deff was never deep in tablet life since I would rather sit at a pc.
A massage connector might be a suitable alternative
what about one of those cheap glue on wireless charing pads you then plug into the charging port?
Was trying to avoid that
