I’m on Debian Bookworm:
Linux wibble 6.1.0-20-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.85-1 (2024-04-11) x86_64 GNU/Linux
I have the latest Nvidia drivers, here’s output from nvidia-smi:
Sat Apr 13 12:57:11 2024
| NVIDIA-SMI 550.54.14 Driver Version: 550.54.14 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA T1000 8GB On | 00000000:08:00.0 Off | N/A |
| 33% 41C P8 N/A / 20W | 0MiB / 8192MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
nvidia-smi -q -d POWER
==============NVSMI LOG==============
Timestamp : Sat Apr 13 12:57:14 2024
Driver Version : 550.54.14
CUDA Version : 12.4
Attached GPUs : 1
GPU 00000000:08:00.0
GPU Power Readings
Power Draw : N/A
Current Power Limit : 20.00 W
Requested Power Limit : 20.00 W
Default Power Limit : 50.00 W
Min Power Limit : 20.00 W
Max Power Limit : 50.00 W
Power Samples
Duration : 118.19 sec
Number of Samples : 119
Max : 25.51 W
Min : 25.50 W
Avg : 25.50 W
GPU Memory Power Readings
Power Draw : N/A
Module Power Readings
Power Draw : N/A
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
I tried running nvidia-smi -pl 20 - which reduces the max, but current still says “N/A”, and I see no difference at the wall.
Can anyone help please with getting this T1000 to the lowest P state, hopefully with the fan off?
