SystemRoot Drivers Not Loading
One Day My computer works fine, the next it doesn't.  I have Win7 Pro that boots off an SSD.  It's incredibly slow to get past the splash screen, and occasionally I have to restart explorer.exe via task manager.  The ntblog shows some root drivers failed to load and I'm assuming this is the issue. It's even slow booting in Safe Mode.
Here is the log:
Service Pack 1 2 15 2015 13:29:33.626
  • Loaded driver \SystemRoot\system32\ntoskrnl.exe
  • Loaded driver \SystemRoot\system32\hal.dll
  • Loaded driver \SystemRoot\system32\kdcom.dll
  • Loaded driver \SystemRoot\system32\mcupdate_GenuineIntel.dll
  • Loaded driver \SystemRoot\system32\PSHED.dll
  • Loaded driver \SystemRoot\system32\CLFS.SYS
  • Loaded driver \SystemRoot\system32\CI.dll
  • Loaded driver \SystemRoot\system32\drivers\Wdf01000.sys
  • Loaded driver \SystemRoot\system32\drivers\WDFLDR.SYS
  • Loaded driver \SystemRoot\system32\drivers\ACPI.sys
  • Loaded driver \SystemRoot\system32\drivers\WMILIB.SYS
  • Loaded driver \SystemRoot\system32\drivers\msisadrv.sys
  • Loaded driver \SystemRoot\system32\drivers\pci.sys
  • Loaded driver \SystemRoot\system32\drivers\vdrvroot.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\iusb3hcs.sys
  • Loaded driver \SystemRoot\System32\drivers\partmgr.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\compbatt.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\BATTC.SYS
  • Loaded driver \SystemRoot\system32\drivers\volmgr.sys
  • Loaded driver \SystemRoot\System32\drivers\volmgrx.sys
  • Loaded driver \SystemRoot\System32\drivers\mountmgr.sys
  • Loaded driver \SystemRoot\system32\drivers\atapi.sys
  • Loaded driver \SystemRoot\system32\drivers\ataport.SYS
  • Loaded driver \SystemRoot\system32\drivers\msahci.sys
  • Loaded driver \SystemRoot\system32\drivers\PCIIDEX.SYS
  • Loaded driver \SystemRoot\system32\drivers\amdxata.sys
  • Loaded driver \SystemRoot\system32\drivers\fltmgr.sys
  • Loaded driver \SystemRoot\system32\drivers\fileinfo.sys
  • Loaded driver \SystemRoot\System32\drivers\WRkrn.sys
  • Loaded driver \SystemRoot\System32\drivers\msrpc.sys
  • Loaded driver \SystemRoot\System32\drivers\NETIO.SYS
  • Loaded driver \SystemRoot\System32\drivers\NDIS.SYS
  • Loaded driver \SystemRoot\System32\drivers\TDI.SYS
  • Loaded driver \SystemRoot\System32\Drivers\Ntfs.sys
  • Loaded driver \SystemRoot\System32\Drivers\ksecdd.sys
  • Loaded driver \SystemRoot\System32\Drivers\cng.sys
  • Loaded driver \SystemRoot\System32\drivers\pcw.sys
  • Loaded driver \SystemRoot\System32\Drivers\Fs_Rec.sys
  • Loaded driver \SystemRoot\System32\Drivers\ksecpkg.sys
  • Loaded driver \SystemRoot\System32\drivers\tcpip.sys
  • Loaded driver \SystemRoot\System32\drivers\fwpkclnt.sys
  • Loaded driver \SystemRoot\system32\drivers\vmstorfl.sys
  • Loaded driver \SystemRoot\system32\drivers\volsnap.sys
  • Loaded driver \SystemRoot\System32\Drivers\spldr.sys
  • Loaded driver \SystemRoot\System32\drivers\rdyboost.sys
  • Loaded driver \SystemRoot\System32\Drivers\mup.sys
  • Loaded driver \SystemRoot\System32\drivers\hwpolicy.sys
  • Loaded driver \SystemRoot\System32\DRIVERS\fvevol.sys
  • Loaded driver \SystemRoot\system32\drivers\disk.sys
  • Loaded driver \SystemRoot\system32\drivers\CLASSPNP.SYS
  • Loaded driver \SystemRoot\system32\DRIVERS\asstor64.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\storport.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\spvdbus.sys
  • Loaded driver \??\C:\Windows\system32\Drivers\spvve.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\cdrom.sys
  • Loaded driver \SystemRoot\System32\Drivers\Null.SYS
  • Loaded driver \SystemRoot\System32\Drivers\Beep.SYS
  • Loaded driver \SystemRoot\System32\drivers\vga.sys
  • Loaded driver \SystemRoot\System32\DRIVERS\RDPCDD.sys
  • Loaded driver \SystemRoot\system32\drivers\rdpencdd.sys
  • Loaded driver \SystemRoot\system32\drivers\rdprefmp.sys
  • Loaded driver \SystemRoot\System32\Drivers\Msfs.SYS
  • Loaded driver \SystemRoot\System32\Drivers\Npfs.SYS
  • Loaded driver \SystemRoot\system32\DRIVERS\tdx.sys
  • Loaded driver \SystemRoot\system32\drivers\afd.sys
  • Loaded driver \SystemRoot\System32\DRIVERS\netbt.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\wfplwf.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\pacer.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\vwififlt.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\netbios.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\wanarp.sys
  • Did not load driver \SystemRoot\system32\DRIVERS\uim_im.sys
  • Did not load driver \SystemRoot\system32\DRIVERS\uim_devim.sys
  • Did not load driver \SystemRoot\system32\DRIVERS\UimBus.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\termdd.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\rdbss.sys
  • Loaded driver \??\C:\Windows\system32\drivers\rawdsk3.sys
  • Loaded driver \SystemRoot\system32\drivers\nsiproxy.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\mssmbios.sys
  • Loaded driver \??\C:\Windows\system32\drivers\ElRawDsk.sys
  • Loaded driver \SystemRoot\System32\drivers\discache.sys
  • Loaded driver \SystemRoot\system32\drivers\csc.sys
  • Loaded driver \SystemRoot\System32\Drivers\dfsc.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\blbdrive.sys
  • Loaded driver \SystemRoot\SysWow64\drivers\AsUpIO.sys
  • Loaded driver \SystemRoot\SysWow64\drivers\AsIO.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\tunnel.sys
  • Loaded driver \SystemRoot\System32\drivers\dxgkrnl.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\nvlddmkm.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\HDAudBus.sys
  • Loaded driver \SystemRoot\SysWow64\drivers\AiChargerPlus.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\iusb3xhc.sys
  • Loaded driver \SystemRoot\SysWow64\drivers\asmtufdriver.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\TeeDriverx64.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\e1d62x64.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\usbehci.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\cthdb.sys
  • Loaded driver \SystemRoot\system32\drivers\ksthunk.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\Rt64win7.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\bcmwl664.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\vwifibus.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\GEARAspiWDM.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\wmiacpi.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\intelppm.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\CompositeBus.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\AgileVpn.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\rasl2tp.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\ndistapi.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\ndiswan.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\raspppoe.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\raspptp.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\rassstp.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\bcmvwl64.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\tap0901.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\tapvyprvpn.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\rdpbus.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\kbdclass.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\mouclass.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\serscan.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\swenum.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\umbus.sys
  • Did not load driver \SystemRoot\System32\drivers\vga.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\usbhub.sys
  • Loaded driver \SystemRoot\system32\drivers\cthda.sys
  • Loaded driver \SystemRoot\System32\Drivers\NDProxy.SYS
  • Did not load driver \SystemRoot\System32\Drivers\NDProxy.SYS
  • Loaded driver \SystemRoot\system32\drivers\nvhda64v.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\iusb3hub.sys
  • Loaded driver \SystemRoot\system32\drivers\HdAudio.sys
  • Loaded driver \SystemRoot\system32\drivers\bcbtums.sys
  • Loaded driver \??\C:\Windows\system32\drivers\btwampfl.sys
  • Loaded driver \SystemRoot\System32\Drivers\BTHUSB.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\usbccgp.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\hidusb.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\rzp1endpt.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\kbdhid.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\rzvmouse.sys
  • Loaded driver \SystemRoot\System32\drivers\mshidkmdf.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\mouhid.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\rzudd.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\rfcomm.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\BthEnum.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\bthpan.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\hidbth.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\btwavdt.sys
  • Loaded driver \SystemRoot\system32\drivers\btwaudio.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\btwl2cap.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\btwrchid.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\monitor.sys
  • Loaded driver \SystemRoot\system32\drivers\luafv.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\PDFsFilter.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\lltdio.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\nwifi.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\ndisuio.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\rspndr.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\vwifimp.sys
  • Loaded driver \SystemRoot\system32\drivers\HTTP.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\bowser.sys
  • Loaded driver \SystemRoot\System32\drivers\mpsdrv.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb10.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb20.sys
  • Loaded driver \SystemRoot\system32\drivers\peauth.sys
  • Loaded driver \SystemRoot\System32\Drivers\secdrv.SYS
  • Loaded driver \SystemRoot\System32\DRIVERS\srvnet.sys
  • Loaded driver \SystemRoot\System32\drivers\tcpipreg.sys
  • Did not load driver \SystemRoot\system32\DRIVERS\PDFsFilter.sys
  • Loaded driver \??\C:\Program Files (x86)\CyberLink\PowerDVD13\Common\NavFilter\000.fcl
  • Loaded driver \SystemRoot\System32\DRIVERS\srv2.sys
  • Loaded driver \SystemRoot\System32\DRIVERS\srv.sys
  • Did not load driver \SystemRoot\System32\DRIVERS\srv.sys
  • Loaded driver \SystemRoot\system32\drivers\WudfPf.sys
  • Loaded driver \SystemRoot\system32\DRIVERS\WUDFRd.sys
  • Loaded driver \??\C:\Program Files (x86)\EVGA Precision X\RTCore64.sys
Any help would be appreciated.
Just reinstall and forget about it. It's windows issue.
