My system crashed once after Asus Dual GeForce RTX 3070, 8GB GDDR6, 256-bit install. I was playing Fallout 76 for a few hours with no problems after the install, GPU temps in the low 60°C, after that I tried the Assassin’s Creed Valhalla benchmark and noticed some dipping in frames. I turned V-sync on and ran the benchmark again, temps where in the mid 60 when the PC went completely OFF, no restarting no power to anything. Managed to get it started after I switched the power supply OFF for a few seconds and then back on. PC started normally and no more problems since (on day later). Any suggestions on what might have happened, new drivers are installed and PC specs are:
Processor AMD Ryzen 7 2700X Eight-Core Processor, 4150 Mhz, 8 Core(s)
BaseBoard Product MSI X370 GAMING PRO CARBON (MS-7A32)
GPU NVIDIA GeForce RTX 3070
RAM Corsair 32GB (2x16) @3000MHz
PSU Seasonic Focus Plus 650 Platinum, Full Modular
Sounds like a power supply overload to me. But that’s just a guess.
I read somewhere that the new Nvidia 3000 GPUs swing their power load from very high to very low much faster than other cards in the past, so the PSU may not react fast enough and hit over-current protections.
it is likely the psu – current inrush protection is too aggressive and tripping. not that your psu isnt 650 w just that the card demands so much power so fast the overcurrent trips.
I used MSI Afterburner (Asus GPU Twek II is broken) to turn Power Limit down to 90% and seems to be OK now. Nvidia really got this lunch wrong… good for AMD and good for me because I have a 60 day return policy no questions asked on the 3070 and I can’t wait to see what AMD can do. I was really disappointed with nvidia and all their misleading info, lack of stock…
I can play Fallout 76 for hours on ultra and I have no problems, if it was a power supply limit this was not possible, when I got the fail is in Assassin’s Creed Valhalla, a newer game that probably pushes the GPU in some weird way.
In the end Seasonic admitted they have a problem with my PSU and newer GPU’s, they checked my SN and advised me to do an RMA… and of curse they’re site has a problem with the RMA page… Hopefully I can get y PSU replaced with a newer version.
