so when i try to luanch sorten applications such as msi afterburner and gba emulater i get an error that states C:\windows\system32\ODBC32.Dll is either not designed to run on windows or it contains anerror.
run sfc /scannow to repair os system files. Or try reinstalling the drivers for afterburner. http://pcsupport.about.com/od/toolsofthetrade/ht/sfc-scannow.htm
ok when i tried running the sfc scannow it said i needed to be administrater to run sfc utilities
right click cmd and do run as administrator. Then type in the command
ok did the repair but it said it found corrupted files but was unable to fix some of the files
Hmm...I would try a clean install of the msi drivers.
ok
ok that might work for msi after burner but what about my gameboy advance emulator
If it says its the same dll that was the problem, i think it will work fine if it works for msi. You also could try messing with the emulator settings if it will do anything.
i would try to mess with the emulater settings but it not even letting me luanch it
I would follow the instructions here:
http://support.microsoft.com/kb/929833
Sorry if im not being helpful.
Are you running a 64-bit or 32-bit ver. of windows?
Just delete it, it will fix 100% of your problems :P
im running a 64nit
64bit*
