Synology Kerberos Authentication from Macs
Hi all,
Pretty obscure one here…
I have a Synology joined to a Windows domain with IWA (integrated windows authentication) enabled. Windows devices can authenticate without an issue.
My issue is that from what I am reading from the Synology documentation is that Kerberos authentication is supported for the web interface.
I have the AD SSO client provisioned on the Mac devices as per Apples profile configuration docs. I have also configured Chrome with the AuthNegotiateDelegateAllowlist and AuthServerAllowlist policies to use the kerberos tickets.
can’t figure out what else I’m missing for this to work. I’ve checked ticket viewer and see the kerberos tickets are valid. I have spun up a windows server with IIS and configured kerberos authentication there as a test and that works just fine. I can see in the IIS logs which users are authenticating.
Thanks for the help folks
– Alex
I would also check which principal the Mac/browser is actually requesting. In a working case you should see a service ticket for HTTP/nas-fqdn@REALM in Ticket Viewer or with klist after hitting the DSM URL. If you browse by short name, alias, IP, or a reverse-proxy name, Chrome may request a different SPN than the one registered on the Synology/AD object. For testing I would use the exact FQDN that matches the SPN, make sure DNS canonicalization is not sending it elsewhere, and check DSM logs or a packet capture for whether it returns a Negotiate challenge at all. If DSM never sends WWW-Authenticate: Negotiate, the browser policy and Kerberos tickets will not matter yet.
