He wants to use A4000 and GTX 970 in 1 pc (he has a spare gpu, that’s why it’s a 970), and wants to swap between which goes in VM and which goes for localhost.
Can this be done? he said he’ll do the software automating if required. I just need a concrete answer and minor explanation on how to. That’s all. Thank you in forward
Personally I solved a similar issue by making a linux VM for playing with ML. So I can stop one VM and start another to swap GPUs between Windows / Linux. A tool like https://looking-glass.io/ can also be handy if you’re between VMs (view output of one GPUin VM on host or in another VM).
Also does the A4000 support vGPU? IIRC the professional nvidia GPUs support that.
You would definitely need to reboot the PC to swap the GPUs. When doing gpu passthrough to VM, it is generally done using a VFIO driver. There are tons of guides on how to do this. Personally, i do it through Grub… in theory a script could be written to change the grub command and run a grub update.
One of the posters suggested VGPU to split the GPU. I could be mistaken, but i am pretty certain you can’t use the ports on the video card when using VGPU, so you would need to remote into the machine.
