Supermicro X10DRG-O+-CPU BIOS fail
Hello, I am having an issue and fear the worst. I just bought a used Supermicro X10DRG-O±CPU off ebay. It was working fine till I tried to update the bios. It was still running on the original BIOS and I needed to update it to use E5-2600v4 CPU’s. It got stuck at one point for hours. I know the rules about power cycling during a BIOS update but I had no choice if I wanted to sleep. No amount of closed doors could handle those fans at full blast. Once I tried turning it back on it is now stuck in a power cycle loop for one second. Not enough time to do anything. Anything I have found online says to roll it back through the IPMI. I am not sure how to access it since all my servers are used so normally I just don’t have access to that because they never reset them. I cant even try because I have no idea what IP it is using. If anyone has any advice that could potentially get my system back up and running I would greatly appreciate it.
Motherboard: X10DRG-O+-CPU | Motherboards | Products | Super Micro Computer, Inc.
