Supermicro H14SSL-NT with PM9A3 M.2 22110 and heatsink in conflict with PCIe cards
So, I’ve had the Supermicro H14SSL-NT for some time now using a single WD Black SN850X 4TB as a boot drive, all good as the HBA sat in a non-conflicting PCIe slot. But now the time has come to complete the build with all its extra PCIe cards and to use both M.2 slots as the rpool (zfs mirror for omnios) and that got me a problem since the M.2 drives sits under the PCIe x8 cards.
One of the two PCIe 5.0 x8 slots will have one Broadcom HBA 9500-16i and the other slot will be free for now. In the three x16 slots I’m going to install the following cards which also may conflict with the M.2 drives.
  • JMT ADT-R37D PCIe5.0x16 to 4-Port EDSFF with either 4x e1.s or e3.s drives
  • ConnectX-6 Dx, MCX623106AC-CDAT
  • PCIe4.0 X16 to 8X M.2 Adapter (Broadcom PEX88048) with 4x m.2 drives with heatsinks
Other considerations is that the build is in the 45drives HL15 2.0 filled with 15x 3.5" drives and cooling is ok but not great when it’s filled with all this stuff. As far as I know there’s no room for thermal pad and heatsinks for the M.2 slots on the motherboard so I’ll have to try to add more fans, even laying around blowing over the M.2 and the PCIe slots.
I was thinking of using the Samsung PM9A3 1.92TB M.2 22110, but they run hot and would benefit from both a thermal pad and a heatsink.
Which M.2 nvme are you using on the motherboard M.2 slots that both clears the PCIe cards and runs cool enough or has room for thermal pad and heatsink?
Or, if you’ve found a thermal pad and heatsink that actually fits the PM9A3 in that location under several PCIe cards, please let me know.
Requirements for the drives are PLP, at least 1 DWPD, at least 1.92TB and of course be able to fit under the mentioned PCIe cards either with pads/heatsink or cool enough without.
Any good advice for this height problem?
