Supermicro H12SSLi MB
Stupid question, but on the Supermicro H12SSLi MB where is the Chassis Power and LED Header located? I do not seem to be able to find it in the diagram based on their naming in the MB manual. Setting up a Proxmox system with SSD/NVMe storage in a Sliger CX4200a chassis and finishing the final connectors…
Any assistance would be greatly appreciated…
You’re looking for header JF1, which is located near the USB4/5 header on the left side, assuming the LAN ports at the rear (so counter-clockwise from the LAN ports). See the diagram on page 10 of the manual. A description of said header can be found in Chapter 2.6 of the aforementioned manual :slight_smile:
Gracias…I have gone over the Manual several times and must of been looking right at it and just missing it…Just want to confirm because the the diagram looks off on where it points to…
Here is the Diagram and here is the board and what it looks like should be the header…
Yeah, that’s the one :slight_smile:
Thank you for the assist…Is the LED header associated with LE1?
Appreciate the assistance…system is setup and running Proxmox with no issues…
In the rack:
Under the cover:
