Supermicro H12SSL-I / EPYC 7702 hangs at POST code 94 (“DXE–BIOS PCI Bus Enumeration”) when a 48 GB VRAM-modded RTX 4090 is installed. System boots normally with the GPU removed. Same behavior on BIOS 3.1 and latest BIOS 3.7/BMC 1.08.03. Above 4G Decoding enabled; ReBAR tested both enabled and disabled; pure UEFI boot; onboard VGA primary. Card was installed in CPU SLOT7 PCIe 4.0 x16. Currently testing SLOT5 to see whether it’s root-port/slot-specific.
Checking post snooping it seems to hit b4 before the whole thing stops.
