Hullo all,
I have a new Supermicro A2SDi-4C-HLN4F motherboard.
For storage this provides 4x normal SATA ports, 4x SATA via a MiniSAS connector (Supermicro include the relevant breakout cable) and 1x M.2 slot.
Also on the board is a physical PCIe slot which Supermicro notes offers “up to x4” - here’s an extract from that product page:
Expansion slots:
1 PCIe 3.0 up to x4 (in x4 slot)*
Flexible I/O - software configurable in BIOS setup
Indeed, navigating to Chipset > South Bridge > Flexible I/O selection shows the 4 choices shown in the screenie below. The factory default was 2nd from top i.e. PCIe x2/Mini SAS/SATA[1:0]
The manual further states the following on page73:
This is a feature on the -2C/4C models only. Up to a total of 8 in selected combinations of SATA ports and four lanes on the PCIe slot can be made available at any given time. Mini SAS offers 4 SATA ports from the Mini SAS HD header. The options are [Mini SAS/SATA(3:0)], [PCIe x2/Mini SAS/SATA (1:0)], [PCIe x4/SATA (3:0)], and [PCIe x4/Mini SAS]
What confuses me is the options in the Southbridge as relating to the SATA and SAS ports.
Examining the Intel Atom C3558 specifications I note a max of 12x PCIe gen3.0 lanes.
So in the board I have, if I’m counting & assigning them correctly we have:
- 4x lanes for the 4x SATA ports
- 4x lanes for the MiniSAS port (used as a break-out to 4x SATA)
- Leaving 4x for the M.2 slot and possible PCIe expansion card.
Does that mean that if you wanted the maximum of 4x PCIe gen3.0 lanes for your expansion card then you would choose either of the lower 2 options - which borrow from the SATA or SAS lanes?
Put another way does the 3rd option “PCIe x4/SATA[3:0]” mean that the SAS port is deactivated?
Any info gratefuly received!
cheers,
Oliver
