hello, i have an fx-6300 @ 4.0 Ghz on stock cooler, the idle temps are 3-5C, i fairly sure this is not right but was wondering if i have a faulty temp senser, also when i feel how hot the heatsink is, it feels around 20-ish.. and at full load max iv gotten is 56C..
no. the amd temp sensors are not accurate. they measure socket temp, not the temp of the cpu. 4.0 on the stock is probably running fairly hot, and you should get a heatsink like the hyper 212...
FX6300 4.0 ghz with stock cooler on fullload 56 C isnt realy that bad idle i think it must be 35 C isnt bad either for a clocked cpu, with a stock cooler..
70C is critical, so i dont seem whats wrong with it?
