Suggestions for Non-Lead Acid Replacement for APC SMT1500C UPS? (Preferably Rackmount)
Hello,
I need to replace my APC SMT1500C UPS. It’s out of warranty and the batteries’ replacement alarm is going off, and I’d rather not just buy more lead-acid batteries to keep it going. It’s in my bedroom office where I sleep, and having a bunch of lead-acid batteries in the same room with me has never been awesome. But apparently it’s even more of a risk than I assumed.
I estimate my idle power usage somewhere around 650w-750w, so 1000w is about the minimum I’d want to ensure some overhead.
This is what I have now:
  • 1440VA/1000W line interactive pure sine wave tower UPS
  • Automatic Voltage Regulation helps correct utility voltage 8x NEMA-15 outlets for output, 120v NEMA-15 input
I sleep and work in here pretty much 24/7, so low noise/silence when it’s not on battery is key. I expect it to scream at me when it’s on actual battery power, both with fans and alarm. That’s fine.
I have a 9U rack, so I was looking at 2U units. A floor unit like I have now would be fine as well, if that’s my only option. My budget is ~$500. (The 2U units I was looking at are reburb’d from a UPS dealer.)
I’d really appreciate any advice. Lithium Ion batteries weren’t even an option the last time I shopped for these. Thanks!
What risk? UPS batteries are of the sealed absorbed glass mat type. They don’t outgas or leak like flooded cells in a car battery.
You already have a UPS it just needs new batteries. So i would just go with the cheaper option of using lead-acid batteries. Even if you replace the batteries every 3 years. It will still be cheaper than buying a LiFePO4 UPS. There just isn’t a big enough market yet for LiFePO4 UPS’s.
However GoldenMate LiFePO4 UPS’s are pretty good. If you must have a LiFePO4 UPS.
@GTwannabe ,
See: APC SMX1500RM2UNC Noise Level Suitable for Bedroom Office?
A couple of very concerned people over there seem convinced I am risking my health by sleeping in the same room with a UPS using SLA batteries.
Given that the other position is sealed, not dangerous unless they catch on fire, I’m pretty confused right now.
I mean, a lithium fire isn’t awesome, either.
@ozlay I have, somehow, 3 UPSes in this room. I want to decommission at least one of them. My current plan is to get a brand new one for the rack to replace the large APC I currently have, and offline one of the floor models.
I may be able to have the new UPS do the work of the third UPS as well, and if that’s the case, I can offline that, too, which would get me down to one. Otherwise, I’ll replace the batteries in that one and be down to two.
