So I decided I kinda want to try streaming some games a little bit. Maybe to YouTube and Twitch, not simultaneously, so i figured I'd give OBS a try.
To be honest I'm not having very good luck. Either my streams are horrible quality, not full screen, bad framerates, ect....
So does anyone have any good advice on settings for streaming with OBS or tutorials? I found a few but I'd figure I'd go to the community first.
I have a 5930K and two R9 390s as well as a 500/500 internet connection. So I think I have the hardware but OBS isn't exactly the most intuitive and I've not been having good luck lol.
I'd like to stream at 1080p but if that isn't possible all good. I could care less about having my webcam in there. It is potato quality anyway and I don't wear low cut tops so no need.
You will need to fiddle around a little with it because every pc is different. That being said this is an older tutorial so if things have changed just ask.
I temporarily give up on obs it doesnt work for recording . I get crap videos and poor fps. On my amd rig with the vcs fork thingie. I ended up using play.tv from inside rapter ap seems to get better performance which is all i need atm for the vid im making for a contest
