Hi there, so I recently did a fresh windows install as I got one of those Phison 1TB E12 M.2 NVME SSD’s (it’s great btw), I didn’t notice this happening on my old install, but maybe it did, I’m not sure. My Ryzen 1700X is currently at 3.8Ghz at 1.275v. It can go higher, up to 4Ghz, but I don’t think it’s worth it with the added heat and voltage. I don’t think the extra 200Mhz will make any real world difference. Educate me if I’m wrong.
The frequency is bouncing all over the place. I’m not sure why, and it’s causing higher than expected idle temps. I was using a Noctua NH-U9S, but upgraded to a U14S for improved cooling and hopefully that third gen 5Ghz. Under load, I’ve seen a 15C decrease in temps doing an AIDA64 stress test (55-56C max, whereas before it was 70C+), but idle temps are still roughly the same, around 35 - 40C when I expected them to be around 28-32C, so I took a look.
I took some videos showing the clock bouncing around, even when doing nothing. Is this normal Ryzen behaviour? I’m a first time OCér. Also, why isn’t it downclocking lower than 2.2Ghz? The lowest P-State is 400Mhz.
If I use the power saver mode, idling it stays at 2.2Ghz. Using High Performance, it stays at 3.8Ghz. Using Balanced, it bounces around making no sense. In the videos. you can see this behavior.
If I’m worrying about nothing, let me know. My only previous experience with modern CPUs is with an Intel i5 2320 and i7 3770, and neither of those displayed this behaviour.
Here are pics of my P-State settings. I only edited P-State 0, then rest are their defaults. It’s not going into P-State 3 which is at 400Mhz.
