Hey good people!
I’m updating a decent number of apps to newer .NET versions, per the majority suggestion. Thanks again btw ![]()
This seems like a pretty divided topic online, but also one that can change drastically with situational context, so I was curious what others’ thoughts were on it: do you ere on the side of using Stored Procedures when calling the database, or do you prefer to use LINQ statements?
Generally, I find it easier to use SPs in most cases, given that it makes the Database team’s job less messy. Additionally, business logic can sometimes be fine tuned or altered without re-deploying the app (maybe having business logic in SQL isn’t the best thing?). SQL Server also appears to handle more complex comparisons much faster than LINQ.
Thoughts? Opinions? Feel free to grind your axe if you had some bad experience ![]()
