Steam Proton and Distros
Hi.
I was wondering if there’s a better distro if you decide to use the new Proton.
The question arises from the fact that Proton usually demands the newest GPU drivers. Would a rolling release be advisable?
Actually Arch recently rolled out the latest Nvidia driver and it caused a regression with Proton. Running bleeding edge isn’t always the best case scenario.
That said, if your running an AMD GPU you do want to be on something recent enough to take advantage of mesa updates. Especially if you intend to run a newly released AMD product. Stability vs performance, is a tricky one to balance.
Id go with Ubuntu 18.10 for stability without staleness, or for rolling try Manjaro, the two week update window allows for people to report issues before they are rolled out. This can help from having any major breakages
(as rare as they are)
There really isn’t a proper distro, but as mentioned there can be regressions.
I use Manjaro because it makes it “easy” to get up and going with proprietary bits while having a fantastic rolling release as a base. But if your main focus is gaming I’m going to have to recommend Mint. Once you add the proprietary repo for GPU drivers you can switch back and forth pretty easily between them using Mints implemented tool.
But honestly, if a distro peaks your interest then try it. If you wanted a distro truly optimized for gaming then Gentoo would even be a viable recommendation as they allow you to set optimizations for packages at compile time.
It comes down to you and your needs. If you have the time then more complex distros like Arch are certainly worth exploring. If there ever is a regression it is often fixed pretty fast.
There isn’t a distro more suited for one case than another because different people have different use cases for them. Hell, if you had the time to maintain it, Tumbleweed on a server isn’t even too bad of an idea with a minimal installation.
So there’s that. There’s also SteamOS if your main focus is Steam. But if your using it for anything else I can’t in my right frame of mind recommend it
Mesa is updated with the Kernel right? Same with AMD opensource drivers isn’t it?
Yes and rolling releases ship with newer kernals. Again, these days so long as your not on something older like Debian or an earlier version of ubuntu ( 16.04 ) Then you should be fine. That said, 18.10 although technically a development build has been pretty stable AFAIK it is running a decent enough version of mesa,xorg and the kernal is recent ( 4.18 )
I would have recommend Mint as it is a great choice once you tweak it. However until Mint 19.1 ships id say it is starting to look a little bit out of date given all the recent updates in drivers.
Also Cinnamon 4.0 is a really nice update (running it on my Arch rig) :slight_smile:
you don’t have to use a rolling distro If you aren’t comfortable with it. the Proton github has links to ubuntu ppas with more recent video drivers to address that part and you can use ukuu to get newer kernels.
That said Arch is great once you have it set up, and you can skip some of the tedium if you use Antergos instead.
Mint is a bad choice because of the way they lazily overload the Ubuntu repositories. It causes all kinds of problems. I’d recommend going with Ubuntu unless you have a really strong reason that Mint is the only option.
That said, I haven’t used it in a few years, so I can’t say if these problems are still as prevalent. I’d imagine they’ll eventually decouple themselves from the Ubuntu repositories.
Isn’t it a bit too soon to go with Ubuntu 18.10?
Is there a way to roll back Mesa from a rolling release (19.0.0-dev) to a stable one (I think it was 18.2.5) on Ubuntu? I have a game crashing on me and I suspect it’s because I choose the rolling release. Meanwhile I have another computer with stable Mesa and it runs fine.
Sorry I am a noob to Manjero, could you tell me where I could find more information about the 2 week update window?
