Steam Link Client now in Beta for Raspbian and the Pi 3 and 3 B+
To install, run the following from a command line:
curl -#Of http://media.steampowered.com/steamlink/rpi/steamlink_1.0.3_armhf.deb
sudo dpkg -i steamlink_1.0.3_armhf.deb
To run, you can launch it from the Games menu, or run the following from a command line:
steamlink
The first time you run it, it will download the full app and create a desktop shortcut, and automatically update as needed.
Thanks for sharing! :slightly_smiling_face: I have no time to check it out right now but I definitely will in the future.
Dude, this is awesome news!
one week
Insert Buzz Lightyear:
Steam Links
Steam Links everywhere
Interesting. Currently I have a version of Moonlight that runs on a RetroPi. Works fairly well wired, but could be better if the Pi had gigabyte Ethernet.
