Hi everyone, can you help a linux noob!
So i have played with the idea of switching to Linux as my primary OS many times and every time there is some huge thing that stops me. Well this time I’m determined to do it for my work laptop, i looked into it and i can do almost everything i need to with a web browser and a decent RDP client there is only one application that “needs” windows, but i can get around that with the RDP client for the most part (i may look at setting it up as a remoteapp, i have read some of the RDP clients for Linux support them)
So far i have tried a few different distros, started with elementary OS got the vpn working and most other things but wasn’t really into it.
Then tried POP OS but there where some things about it that got on my nerves and now I’m trying Ubuntu Budgie
Got everything going just fine except for the VPN which seems strange as it worked fine on elementary OS and i thought they are both based on ubuntu?
Did some looking into it and i keep coming across that there is a bug in 20.04 that stops SSTP from working, i can setup the connection but then when i try to connect the switch icon will switch “on” then immediately turn “off” again.
I know it should work as i had it working just fine in elementary OS.
Does anyone have any suggestions or a known work around, or do i need to go back to elementary OS?
Any help greatly appreciated.
