Hello dear enthusiasts.
I have been a silent watcher and reader of L1 and this forum for a while, but today I’m active the first time since I really need some help.
I’m trying to set up a little homelab, with the primary and lonely host running Ubuntu-server 22.04, 5.15.0-117-generic.
It’s also the primary VPN gateway into my homenetwork, and it is running docker with some http applications, the reverse proxy of my choice being traefik.
Of course I also have SSHD running locally on the host.
To be as little annoyed by overreaching firewalls and censorships of other kinds, I stubbornly decided to funnel all encrypted TCP traffic through port 443.
To realize that, I want to run the FOSS SSLH (GitHub - yrutschle/sslh: Applicative Protocol Multiplexer (e.g. share SSH and HTTPS on the same port)) inside of docker, as that is the easiest way to update it.
OpenSSH and OpenVPN are running directly on the host.
Traefik of course is running in docker.
The goal is to run SSLH in transparent mode, so that I can still use fail2ban in SSH, so that my http applications will end up with correct logs.
For this the repository provides a two part instruction:
What I have got so far:
SSLH container:
services:
sslh:
image: ghcr.io/yrutschle/sslh:master
container_name: sslh
environment:
- TZ=Berlin/Europe
security_opt:
- no-new-privileges=false
cap_add:
- NET_ADMIN
- NET_RAW
- NET_BIND_SERVICE
#sysctls:
# - net.ipv4.conf.default.route_localnet=1
# - net.ipv4.conf.all.route_localnet=1
command: --listen 192.168.172.55:443 --transparent --foreground --ssh 192.168.255.254:22 --tls 192.168.255.254:8443 --http 192.168.255.254:8080 --verbose=3
network_mode: host
ports:
- target: 443
published: 443
protocol: tcp
mode: host
restart: unless-stopped
Created a dummy0 interface at 192.168.255.254:
user@ubuntuserver:~$ cat /etc/network/interfaces
auto dummy0
iface dummy0 inet static
address 192.168.255.254/32
pre-up modprobe dummy
## Attention! with kernels, not automatically creating a dummy0
## interface after module loading the following line should be:
pre-up modprobe dummy; if [ ! -e /sys/class/net/dummy0 ]; then ip link add dummy0 type dummy ; fi
post-up ip rule add from 192.168.255.254 table sslh
post-up ip route add local 0.0.0.0/0 dev dummy0 table sslh
pre-down ip route del local 0.0.0.0/0 dev dummy0 table sslh
pre-down ip rule del from 192.168.255.254 table sslh
Predifined a routing table:
user@ubuntuserver:~$ cat /etc/iproute2/rt_tables
# reserved values
111 sslh
With this configuration, applications running locally on the host work perfectly, and transparently even. SSHD logs the actual public IP of my client.
Even a small python http server I set up for testing is accessable.
However, if I try to access either a small Nginx-demo or traefik back in docker, I get nothing.
What I already tried:
What I already checked and tried:
-in principle everything can reach (as in ping) everything. The sslh container can ping my Nginx-demo container ( for the final config I would be running traefik here instead)
-If I try to access the nginx-demo on localserverip:8443, it works
-If I route directly to the demo container instead of the dummy0 interface, it doesn’t work, neither if I route to local host or the eth0 ip (localserverip or 192.168.172.55 as in the sslh config)
The configuration guide makes mention of this, but does not expand sufficiently for a tomato like me to actually understand it. I quote:
Remote Setups
This concept can also be adapted for several setups, where the sshd (or any other target service) is running in a container, kvm-virtual machine, etc. Precondition is, that the target system is the next hop and uses the sslh-hosting system as default gateway. In addition you need to bind an additional ip-address, solely used for sshd on the corresponding interface. Than you can adapt the routing rule, routing traffic coming back from this ip to the sslh-routing-table. Its also possible, to forward to an next hop system, which has its own default gateway back, bypassing the sslh-host. In this case, you need to add a special route back to the sslh host, for all traffic with the sshd source ip address. This can be done similar to the two rules described above:# first define a name for the table in /etc/iproute2/rt_tables e.g. sslh-routeback ip rule add from IPADRESS-OF-SERVIE table sslh-routeback ip route add default via IPADDRESS-OF_SSLH-HOST dev eth0 table sslh-routebackThe details are depending on your network settings. Als long, as the forward chain to the hidden service passes systems under your control, you can add backroutes on each system in that route. Precondition: The used ip address produces no conflict on those systems.
And while I understand a lot of these words on their own and not together, after trying and messing around for a week or so now, I just can’t get it done.
I’d be incredibly grateful if somebody could take me figuratively by the hand and explain this to me in the way a prosumer but not exactly network engineer can configure this.
Thank you all
