So I have a testing environment built and ready to document this very boring task.
Hypotheses:
1.) SSD’s use more power and generate more waste heat (according to most data sheets), though if the workload completes substantially faster than an HDD, the power usage will peak higher but total lower.
2.) Local workloads will benefit more from SSD than network workloads until >1Gbps interfaces are used until a point where SSD’s will be the overall winner.
3.) Power consumption vs. performance increase is relative based on electric costs. The potential savings may not justify the increased expense.
Testing:
Power consumption is tracked over a 24 hour period at the outlet
Usage will be scripted benchmarks simulating standard loading with default Server 2022 power management enabled.
It’s an i5-9500T, 16 GB RAM, H310M M.2 2.0 board, 256 GB Samsung 970 EVO boot drive, with an add in TPM module and onboard gigabit
Open air with the only fan being the CPU fan
An add in 25 or 100 gig card may be used to simulate high throughput network utilization with client power consumption not recorded.
On the agenda:
M.2 NVME - 2TB MLC, 4TB QLC
SATA SSD - 2TB MLC, 4TB QLC
U.2 NVME - Gen 3x4 3.2TB mixed use drive in passive interface card
3.5" HDD - 4TB CMR, 22TB CMR enterprise drive
2.5" HDD - 1TB CMR laptop drive, 1TB CMR enterprise drive, 4TB SMR
What workloads and benchmarks would you like to see?
What network based workloads?
General thoughts?
