SSD question
Hey,
So, I got half of a computer for Christmas (GPU, CPU, Mobo, HDD) and I am now able to afford a SSD in the 100 dollar range. So my question is, would an Intel 330 120GB SSD ( http://www.newegg.ca/Product/Product.aspx?Item=N82E16820167121 ) be worth the twenty extra dollars over the 90$ (boxing day deal) Samsung 840 series. http://www.newegg.ca/Product/Product.aspx?Item=N82E16820147188
Thanks!
Get a Kingston HyperX 3k.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820239045
Get a cake.
If your motherboard supports cache, use it for that. Get an Intel or OCZ 60GB SSD because it will be painful when you find out you have run out of space. Plus, you will want to re-install Windows or whatever OS you are using or you will get dire performance compared to a native install.
And then, yes, buy yourself a cake.
