glxinfo
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_no_error,
GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer, GLX_OML_swap_method,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent,
GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_OML_swap_method,
GLX_OML_sync_control, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
Extended renderer info (GLX_MESA_query_renderer):
Vendor: AMD (0x1002)
Device: AMD TAHITI (DRM 2.50.0, 5.11.0-27-generic, LLVM 12.0.0) (0x679a)
Version: 21.0.3
Accelerated: yes
Video memory: 3072MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 4.5
Max compat profile version: 4.5
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
Memory info (GL_ATI_meminfo):
VBO free memory - total: 3072 MB, largest block: 3072 MB
VBO free aux. memory - total: 2043 MB, largest block: 2043 MB
Texture free memory - total: 3072 MB, largest block: 3072 MB
Texture free aux. memory - total: 2043 MB, largest block: 2043 MB
Renderbuffer free memory - total: 3072 MB, largest block: 3072 MB
Renderbuffer free aux. memory - total: 2043 MB, largest block: 2043 MB
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 3072 MB
Total available memory: 5115 MB
Currently available dedicated video memory: 3072 MB
OpenGL vendor string: AMD
OpenGL renderer string: AMD TAHITI (DRM 2.50.0, 5.11.0-27-generic, LLVM 12.0.0)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 21.0.3
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_conservative_depth, GL_AMD_depth_clamp_separate,
GL_AMD_draw_buffers_blend, GL_AMD_gpu_shader_int64,
GL_AMD_multi_draw_indirect, GL_AMD_performance_monitor,
GL_AMD_pinned_memory, GL_AMD_query_buffer_object,
GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_stencil_export,
GL_AMD_shader_trinary_minmax, GL_AMD_texture_texture4,
GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_bindless_texture,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_compute_shader, GL_ARB_compute_variable_group_size,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
GL_ARB_derivative_control, GL_ARB_direct_state_access,
GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_gl_spirv,
GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
GL_ARB_multi_draw_indirect, GL_ARB_occlusion_query2,
GL_ARB_parallel_shader_compile, GL_ARB_pipeline_statistics_query,
GL_ARB_pixel_buffer_object, GL_ARB_point_sprite,
GL_ARB_polygon_offset_clamp, GL_ARB_program_interface_query,
GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,
GL_ARB_shader_atomic_counter_ops, GL_ARB_shader_atomic_counters,
GL_ARB_shader_ballot, GL_ARB_shader_bit_encoding, GL_ARB_shader_clock,
GL_ARB_shader_group_vote, GL_ARB_shader_image_load_store,
GL_ARB_shader_image_size, GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_stencil_export, GL_ARB_shader_storage_buffer_object,
GL_ARB_shader_subroutine, GL_ARB_shader_texture_image_samples,
GL_ARB_shader_texture_lod, GL_ARB_shader_viewport_layer_array,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
GL_ARB_shading_language_packing, GL_ARB_spirv_extensions,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
GL_ARB_texture_barrier, GL_ARB_texture_buffer_object,
GL_ARB_texture_buffer_object_rgb32, GL_ARB_texture_buffer_range,
GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map_array, GL_ARB_texture_filter_anisotropic,
GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_multisample,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query,
GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,
GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_uniform_buffer_object,
GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_viewport_array, GL_ATI_blend_equation_separate, GL_ATI_meminfo,
GL_ATI_texture_float, GL_ATI_texture_mirror_once,
GL_EXT_EGL_image_storage, GL_EXT_EGL_sync, GL_EXT_abgr,
GL_EXT_blend_equation_separate, GL_EXT_demote_to_helper_invocation,
GL_EXT_depth_bounds_test, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
GL_EXT_framebuffer_sRGB, GL_EXT_memory_object, GL_EXT_memory_object_fd,
GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
GL_EXT_provoking_vertex, GL_EXT_shader_image_load_formatted,
GL_EXT_shader_image_load_store, GL_EXT_shader_integer_mix,
GL_EXT_shader_samples_identical, GL_EXT_texture_array,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_integer, GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shadow_lod, GL_EXT_texture_shared_exponent,
GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,
GL_EXT_vertex_attrib_64bit, GL_EXT_window_rectangles,
GL_IBM_multimode_draw_arrays, GL_INTEL_blackhole_render,
GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control,
GL_KHR_debug, GL_KHR_no_error, GL_KHR_parallel_shader_compile,
GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
GL_KHR_texture_compression_astc_ldr,
GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_framebuffer_flip_y,
GL_MESA_pack_invert, GL_MESA_shader_integer_functions,
GL_MESA_texture_signed_rgba, GL_NVX_gpu_memory_info,
GL_NV_alpha_to_coverage_dither_control, GL_NV_compute_shader_derivatives,
GL_NV_conditional_render, GL_NV_copy_image, GL_NV_depth_clamp,
GL_NV_packed_depth_stencil, GL_NV_shader_atomic_int64,
GL_NV_texture_barrier, GL_NV_vdpau_interop, GL_OES_EGL_image, GL_S3_s3tc
OpenGL version string: 4.5 (Compatibility Profile) Mesa 21.0.3
OpenGL shading language version string: 4.50
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
GL_AMD_draw_buffers_blend, GL_AMD_multi_draw_indirect,
GL_AMD_performance_monitor, GL_AMD_pinned_memory,
GL_AMD_query_buffer_object, GL_AMD_seamless_cubemap_per_texture,
GL_AMD_shader_stencil_export, GL_AMD_shader_trinary_minmax,
GL_AMD_texture_texture4, GL_AMD_vertex_shader_layer,
GL_AMD_vertex_shader_viewport_index, GL_ANGLE_texture_compression_dxt3,
GL_ANGLE_texture_compression_dxt5, GL_APPLE_packed_pixels,
GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,
GL_ARB_bindless_texture, GL_ARB_blend_func_extended,
GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
GL_ARB_clip_control, GL_ARB_color_buffer_float, GL_ARB_compatibility,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
GL_ARB_compute_variable_group_size, GL_ARB_conditional_render_inverted,
GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_ARB_direct_state_access, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_multi_draw_indirect, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shading_language_100, GL_ARB_shading_language_420pack,
GL_ARB_shading_language_include, GL_ARB_shading_language_packing,
GL_ARB_shadow, GL_ARB_spirv_extensions, GL_ARB_stencil_texturing,
GL_ARB_sync, GL_ARB_tessellation_shader, GL_ARB_texture_barrier,
GL_ARB_texture_border_clamp, GL_ARB_texture_buffer_object,
GL_ARB_texture_compression, GL_ARB_texture_compression_bptc,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_filter_anisotropic,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_stencil8, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_64bit,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_blend_equation_separate,
GL_ATI_draw_buffers, GL_ATI_fragment_shader, GL_ATI_meminfo,
GL_ATI_separate_stencil, GL_ATI_texture_compression_3dc,
GL_ATI_texture_env_combine3, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_EXT_EGL_image_storage, GL_EXT_EGL_sync,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_copy_texture, GL_EXT_demote_to_helper_invocation,
GL_EXT_depth_bounds_test, GL_EXT_direct_state_access,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_sRGB, GL_EXT_gpu_program_parameters,
GL_EXT_gpu_shader4, GL_EXT_memory_object, GL_EXT_memory_object_fd,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shader_image_load_formatted,
GL_EXT_shader_samples_identical, GL_EXT_shadow_funcs,
GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_array,
GL_EXT_texture_buffer_object, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,
GL_EXT_transform_feedback, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_INTEL_blackhole_render, GL_KHR_blend_equation_advanced,
GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
GL_KHR_parallel_shader_compile, GL_KHR_robust_buffer_access_behavior,
GL_KHR_robustness, GL_KHR_texture_compression_astc_ldr,
GL_MESA_texture_signed_rgba, GL_MESA_window_pos, GL_NVX_gpu_memory_info,
GL_NV_alpha_to_coverage_dither_control, GL_NV_blend_square,
GL_NV_compute_shader_derivatives, GL_NV_conditional_render,
GL_NV_copy_depth_to_color, GL_NV_copy_image, GL_NV_depth_clamp,
GL_NV_fog_distance, GL_NV_half_float, GL_NV_light_max_exponent,
GL_NV_packed_depth_stencil, GL_NV_primitive_restart,
GL_NV_shader_atomic_int64, GL_NV_texgen_reflection, GL_NV_texture_barrier,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_NV_vdpau_interop,
GL_OES_EGL_image, GL_OES_read_format, GL_S3_s3tc,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.0.3
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
GL_AMD_performance_monitor, GL_ANDROID_extension_pack_es31a,
GL_ANGLE_pack_reverse_row_order, GL_ANGLE_texture_compression_dxt3,
GL_ANGLE_texture_compression_dxt5, GL_APPLE_texture_max_level,
GL_EXT_EGL_image_storage, GL_EXT_base_instance,
GL_EXT_blend_func_extended, GL_EXT_blend_minmax, GL_EXT_buffer_storage,
GL_EXT_clip_control, GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float,
GL_EXT_color_buffer_half_float, GL_EXT_compressed_ETC1_RGB8_sub_texture,
GL_EXT_copy_image, GL_EXT_demote_to_helper_invocation, GL_EXT_depth_clamp,
GL_EXT_discard_framebuffer, GL_EXT_disjoint_timer_query,
GL_EXT_draw_buffers, GL_EXT_draw_buffers_indexed,
GL_EXT_draw_elements_base_vertex, GL_EXT_draw_instanced,
GL_EXT_float_blend, GL_EXT_frag_depth, GL_EXT_geometry_point_size,
GL_EXT_geometry_shader, GL_EXT_gpu_shader5, GL_EXT_map_buffer_range,
GL_EXT_memory_object, GL_EXT_memory_object_fd, GL_EXT_multi_draw_arrays,
GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
GL_EXT_primitive_bounding_box, GL_EXT_read_format_bgra,
GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB_write_control,
GL_EXT_separate_shader_objects, GL_EXT_shader_group_vote,
GL_EXT_shader_implicit_conversions, GL_EXT_shader_integer_mix,
GL_EXT_shader_io_blocks, GL_EXT_shader_samples_identical,
GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader,
GL_EXT_texture_border_clamp, GL_EXT_texture_buffer,
GL_EXT_texture_compression_bptc, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_compression_s3tc_srgb, GL_EXT_texture_cube_map_array,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_format_BGRA8888,
GL_EXT_texture_norm16, GL_EXT_texture_query_lod, GL_EXT_texture_rg,
GL_EXT_texture_shadow_lod, GL_EXT_texture_type_2_10_10_10_REV,
GL_EXT_texture_view, GL_EXT_unpack_subimage, GL_EXT_window_rectangles,
GL_MESA_shader_integer_functions, GL_NV_alpha_to_coverage_dither_control,
GL_NV_draw_buffers, GL_NV_fbo_color_attachments, GL_NV_image_formats,
GL_NV_pixel_buffer_object, GL_NV_read_buffer, GL_NV_read_depth,
GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image,
GL_OES_EGL_image_external, GL_OES_EGL_image_external_essl3,
GL_OES_EGL_sync, GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image,
GL_OES_depth24, GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
GL_OES_geometry_point_size, GL_OES_geometry_shader,
GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer,
GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box,
GL_OES_required_internalformat, GL_OES_rgb8_rgba8, GL_OES_sample_shading,
GL_OES_sample_variables, GL_OES_shader_image_atomic,
GL_OES_shader_io_blocks, GL_OES_shader_multisample_interpolation,
GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_surfaceless_context,
GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_buffer,
GL_OES_texture_cube_map_array, GL_OES_texture_float,
GL_OES_texture_float_linear, GL_OES_texture_half_float,
GL_OES_texture_half_float_linear, GL_OES_texture_npot,
GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
GL_OES_texture_view, GL_OES_vertex_array_object, GL_OES_vertex_half_float,
GL_OES_viewport_array
504 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x022 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x4df 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x4e0 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x4e1 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x4e2 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x4e3 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x4e4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x4e5 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x4e6 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x4e7 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x4e8 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x4e9 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x4ea 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x4eb 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x4ec 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x4ed 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x4ee 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x4ef 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x4f0 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x4f1 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x4f2 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x4f3 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x4f4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x4f5 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x4f6 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x4f7 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x4f8 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x4f9 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x4fa 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x4fb 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x4fc 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x4fd 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x4fe 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x4ff 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x500 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x501 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x502 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x503 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x504 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x505 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x506 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x507 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x508 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x509 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x50a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x50b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x50c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x50d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x50e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x50f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x510 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x511 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x512 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x513 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x514 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x515 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x516 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x517 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x518 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x519 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x51a 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x51b 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x51c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x51d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x51e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x51f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x520 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x521 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x522 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x523 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x524 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x525 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x526 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x527 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x528 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x529 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x52a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x52b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x52c 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x52d 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x52e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x52f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x530 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x531 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x532 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x533 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x534 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x535 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x536 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x537 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x538 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x539 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x53a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x53b 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x53c 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x53d 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x53e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x53f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x540 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x541 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x542 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x543 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x544 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x545 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x546 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x547 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x548 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x549 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x54a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x54b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x54c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x54d 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x54e 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x54f 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x550 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x551 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x552 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x553 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x554 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x555 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x556 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x557 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x558 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x559 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x55a 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x55b 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x55c 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x55d 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x55e 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x55f 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x560 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x561 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x562 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x563 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x564 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x565 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x566 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x567 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x568 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x569 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x56a 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x56b 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x56c 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x56d 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x56e 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x56f 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x570 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 8 1 None
0x571 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x572 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x573 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 8 1 None
0x574 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x575 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x576 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 8 1 None
0x577 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x578 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x579 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 8 1 None
0x57a 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x57b 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x57c 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 8 1 None
0x57d 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x57e 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x57f 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 8 1 None
0x580 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x581 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x582 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 8 1 None
0x583 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x584 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x585 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 8 1 None
0x586 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x587 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x588 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 8 1 None
0x589 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x58a 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x58b 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 8 1 None
0x58c 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x58d 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x58e 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 8 1 None
0x58f 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x590 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x591 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 8 1 None
0x592 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x593 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x594 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x595 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x596 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x597 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x598 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x599 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x59a 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x59b 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x59c 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x59d 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x59e 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x59f 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x5a0 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x5a1 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x5a2 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x5a3 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x5a4 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x5a5 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x5a6 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x5a7 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x5a8 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x5a9 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x5aa 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x5ab 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x5ac 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 8 1 None
0x5ad 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x5ae 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x5af 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 8 1 None
0x5b0 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x5b1 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x5b2 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 8 1 None
0x5b3 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x5b4 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x5b5 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 8 1 None
0x5b6 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x5b7 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x5b8 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 8 1 None
0x5b9 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x5ba 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x5bb 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 8 1 None
0x5bc 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x5bd 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x5be 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 8 1 None
0x5bf 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x5c0 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x5c1 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 8 1 None
0x5c2 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x5c3 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x5c4 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 8 1 None
0x5c5 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x5c6 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x5c7 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 8 1 None
0x5c8 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x5c9 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x5ca 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 8 1 None
0x5cb 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x5cc 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x5cd 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 8 1 None
0x5ce 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x5cf 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x5d0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x5d1 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x5d2 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x5d3 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x5d4 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x5d5 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x5d6 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x5d7 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x5d8 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x5d9 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x5da 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x5db 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x5dc 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x5dd 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x5de 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x5df 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x5e0 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x5e1 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x5e2 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x5e3 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x5e4 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x5e5 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x5e6 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x5e7 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x5e8 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x5e9 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x5ea 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x5eb 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x5ec 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x5ed 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x5ee 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x5ef 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x5f0 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x5f1 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x5f2 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x5f3 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x5f4 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x5f5 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x5f6 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x5f7 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x5f8 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x5f9 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x5fa 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x5fb 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x5fc 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x5fd 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x5fe 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x5ff 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x600 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x601 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x602 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x603 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x604 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x605 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x606 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x607 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x608 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x609 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x60a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x60b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x60c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x60d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x60e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x60f 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x610 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x611 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x612 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x613 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x614 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x615 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x616 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x617 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x618 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x619 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x61a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x61b 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x61c 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x61d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x61e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x61f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x620 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x621 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x622 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x623 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x624 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x625 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x626 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x627 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x628 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x629 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x62a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x62b 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x62c 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x62d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x62e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x62f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x630 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x631 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x632 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x633 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x634 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x635 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x636 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x637 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x638 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x639 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x63a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x63b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x63c 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x63d 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x63e 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x63f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x640 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x641 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x642 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x643 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x644 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x645 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x646 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x647 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x648 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x649 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x64a 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x64b 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x64c 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x64d 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x64e 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x64f 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x650 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x651 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x652 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x653 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x654 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x655 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x656 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x657 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x658 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x659 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x65a 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x65b 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x65c 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x65d 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x65e 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x65f 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 8 1 None
0x660 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x661 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x662 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 8 1 None
0x663 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x664 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x665 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 8 1 None
0x666 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x667 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x668 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 8 1 None
0x669 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x66a 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x66b 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 8 1 None
0x66c 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x66d 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x66e 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 8 1 None
0x66f 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x670 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x671 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 8 1 None
0x672 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x673 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x674 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 8 1 None
0x675 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x676 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x677 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 8 1 None
0x678 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x679 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x67a 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 8 1 None
0x67b 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x67c 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x67d 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 8 1 None
0x67e 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x67f 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x680 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 8 1 None
0x681 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x682 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x683 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x684 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x685 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x686 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x687 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x688 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x689 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x68a 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x68b 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x68c 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x68d 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x68e 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x68f 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x690 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x691 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x692 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x693 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x694 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x695 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x696 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x697 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x698 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x699 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x69a 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x69b 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 8 1 None
0x69c 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x69d 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x69e 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 8 1 None
0x69f 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x6a0 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x6a1 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 8 1 None
0x6a2 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x6a3 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x6a4 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 8 1 None
0x6a5 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x6a6 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x6a7 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 8 1 None
0x6a8 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x6a9 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x6aa 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 8 1 None
0x6ab 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x6ac 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x6ad 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 8 1 None
0x6ae 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x6af 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x6b0 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 8 1 None
0x6b1 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x6b2 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x6b3 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 8 1 None
0x6b4 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x6b5 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x6b6 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 8 1 None
0x6b7 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x6b8 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x6b9 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 8 1 None
0x6ba 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x6bb 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x6bc 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 8 1 None
0x08e 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x6bd 32 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x6be 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x6bf 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x6c0 32 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x6c1 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x6c2 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x6c3 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x6c4 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x6c5 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x6c6 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x6c7 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x6c8 32 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x6c9 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x6ca 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x6cb 32 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x6cc 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x6cd 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x6ce 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x6cf 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x6d0 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x6d1 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x6d2 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x6d3 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
1104 GLXFBConfigs:
0x08f 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 None
0x090 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 16 16 16 16 0 0 Slow
0x091 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 None
0x092 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 16 16 16 16 0 0 Slow
0x093 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 None
0x094 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 16 16 16 16 0 0 Slow
0x095 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 0 0 None
0x096 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 16 16 16 16 0 0 Slow
0x097 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 0 0 None
0x098 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 16 16 16 16 0 0 Slow
0x099 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 0 0 None
0x09a 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 16 16 16 16 0 0 Slow
0x09b 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 0 0 None
0x09c 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 16 16 16 16 0 0 Slow
0x09d 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 0 0 None
0x09e 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 16 16 16 16 0 0 Slow
0x09f 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 0 0 None
0x0a0 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 16 16 16 16 0 0 Slow
0x0a1 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 0 0 None
0x0a2 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 16 16 16 16 0 0 Slow
0x0a3 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 0 0 None
0x0a4 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 16 16 16 16 0 0 Slow
0x0a5 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 0 0 None
0x0a6 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 16 16 16 16 0 0 Slow
0x0a7 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 2 1 None
0x0a8 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 4 1 None
0x0a9 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 8 1 None
0x0aa 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 2 1 None
0x0ab 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 4 1 None
0x0ac 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 8 1 None
0x0ad 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 2 1 None
0x0ae 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 4 1 None
0x0af 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 8 1 None
0x0b0 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 2 1 None
0x0b1 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 4 1 None
0x0b2 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 8 1 None
0x0b3 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 2 1 None
0x0b4 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 4 1 None
0x0b5 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 8 1 None
0x0b6 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 2 1 None
0x0b7 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 4 1 None
0x0b8 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 8 1 None
0x0b9 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 2 1 None
0x0ba 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 4 1 None
0x0bb 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 8 1 None
0x0bc 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 2 1 None
0x0bd 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 4 1 None
0x0be 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 8 1 None
0x0bf 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 2 1 None
0x0c0 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 4 1 None
0x0c1 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 8 1 None
0x0c2 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 2 1 None
0x0c3 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 4 1 None
0x0c4 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 8 1 None
0x0c5 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 2 1 None
0x0c6 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 4 1 None
0x0c7 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 8 1 None
0x0c8 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 2 1 None
0x0c9 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 4 1 None
0x0ca 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 8 1 None
0x0cb 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 0 0 None
0x0cc 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0cd 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 0 0 None
0x0ce 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0cf 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 0 0 None
0x0d0 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0d1 0 tc 0 30 0 r . . 10 10 10 0 . . 0 16 0 0 0 0 0 0 0 None
0x0d2 0 tc 0 30 0 r . . 10 10 10 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0d3 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 0 0 None
0x0d4 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0d5 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 0 0 None
0x0d6 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0d7 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 0 0 0 0 0 0 0 None
0x0d8 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0d9 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 0 0 None
0x0da 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0db 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 0 0 None
0x0dc 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0dd 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 8 0 0 0 0 0 0 None
0x0de 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0df 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 0 0 None
0x0e0 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0e1 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 0 0 None
0x0e2 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0e3 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 2 1 None
0x0e4 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 4 1 None
0x0e5 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 8 1 None
0x0e6 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 2 1 None
0x0e7 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 4 1 None
0x0e8 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 8 1 None
0x0e9 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 2 1 None
0x0ea 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 4 1 None
0x0eb 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 8 1 None
0x0ec 0 tc 0 30 0 r . . 10 10 10 0 . . 0 16 0 0 0 0 0 2 1 None
0x0ed 0 tc 0 30 0 r . . 10 10 10 0 . . 0 16 0 0 0 0 0 4 1 None
0x0ee 0 tc 0 30 0 r . . 10 10 10 0 . . 0 16 0 0 0 0 0 8 1 None
0x0ef 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 2 1 None
0x0f0 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 4 1 None
0x0f1 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 8 1 None
0x0f2 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 2 1 None
0x0f3 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 4 1 None
0x0f4 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 8 1 None
0x0f5 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 0 0 0 0 0 2 1 None
0x0f6 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 0 0 0 0 0 4 1 None
0x0f7 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 0 0 0 0 0 8 1 None
0x0f8 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 2 1 None
0x0f9 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 4 1 None
0x0fa 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 8 1 None
0x0fb 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 2 1 None
0x0fc 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 4 1 None
0x0fd 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 8 1 None
0x0fe 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 8 0 0 0 0 2 1 None
0x0ff 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 8 0 0 0 0 4 1 None
0x100 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 8 0 0 0 0 8 1 None
0x101 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 2 1 None
0x102 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 4 1 None
0x103 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 8 1 None
0x104 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 2 1 None
0x105 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 4 1 None
0x106 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 8 1 None
0x107 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 None
0x108 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 16 16 16 16 0 0 Slow
0x109 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 None
0x10a 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 16 16 16 16 0 0 Slow
0x10b 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 None
0x10c 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 16 16 16 16 0 0 Slow
0x10d 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 0 0 None
0x10e 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 16 16 16 16 0 0 Slow
0x10f 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 0 0 None
0x110 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 16 16 16 16 0 0 Slow
0x111 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 0 0 None
0x112 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 16 16 16 16 0 0 Slow
0x113 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 0 0 None
0x114 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 16 16 16 16 0 0 Slow
0x115 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 0 0 None
0x116 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 16 16 16 16 0 0 Slow
0x117 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 0 0 None
0x118 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 16 16 16 16 0 0 Slow
0x119 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 0 0 None
0x11a 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 16 16 16 16 0 0 Slow
0x11b 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 0 0 None
0x11c 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 16 16 16 16 0 0 Slow
0x11d 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 0 0 None
0x11e 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 16 16 16 16 0 0 Slow
0x11f 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 2 1 None
0x120 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 4 1 None
0x121 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 8 1 None
0x122 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 2 1 None
0x123 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 4 1 None
0x124 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 8 1 None
0x125 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 2 1 None
0x126 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 4 1 None
0x127 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 8 1 None
0x128 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 2 1 None
0x129 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 4 1 None
0x12a 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 8 1 None
0x12b 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 2 1 None
0x12c 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 4 1 None
0x12d 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 8 1 None
0x12e 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 2 1 None
0x12f 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 4 1 None
0x130 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 8 1 None
0x131 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 2 1 None
0x132 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 4 1 None
0x133 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 8 1 None
0x134 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 2 1 None
0x135 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 4 1 None
0x136 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 8 1 None
0x137 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 2 1 None
0x138 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 4 1 None
0x139 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 8 1 None
0x13a 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 2 1 None
0x13b 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 4 1 None
0x13c 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 8 1 None
0x13d 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 2 1 None
0x13e 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 4 1 None
0x13f 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 8 1 None
0x140 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 2 1 None
0x141 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 4 1 None
0x142 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 8 1 None
0x143 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 0 0 None
0x144 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x145 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 0 0 None
0x146 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x147 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 0 0 None
0x148 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x149 0 tc 0 30 0 r . . 10 10 10 0 . . 0 16 0 0 0 0 0 0 0 None
0x14a 0 tc 0 30 0 r . . 10 10 10 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x14b 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 0 0 None
0x14c 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x14d 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 0 0 None
0x14e 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x14f 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 0 0 0 0 0 0 0 None
0x150 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x151 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 0 0 None
0x152 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x153 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 0 0 None
0x154 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x155 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 8 0 0 0 0 0 0 None
0x156 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x157 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 0 0 None
0x158 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x159 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 0 0 None
0x15a 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x15b 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 2 1 None
0x15c 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 4 1 None
0x15d 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 8 1 None
