Long explanation ahead, for a quickie skip to the TL;DR at the end:
I want to seperate church and state. Meaning: I want to seperate gaming and "work". My reasoning is: Most of the time I do work on my computer (University work mostly so think of: programming .... writing scripts .... messing around with stuff that requires zero CPU power) while my GPU (AMD/ATI HD6870) is trying it's best to imitate a leaf blower. I already found the relevant fan-speed settings in the AMD driver to tell it to be the most quiet it can be (which is not really quiet). Since I recently upgraded my CPU to a FX8320E to have 8 threads to play around with I have my old FX-4170 just collecting dust.
Current config:
AMD FX-8320E on a Gigabyte GA970A-D3
16 Gigabyte of RAM
AMD/ATI HD6870
Thermaltake 500 Watt PSU
drives and peripherals are not important but present
Spare hardware:
AMD FX-4170
AMD/ATI R5 230 flex
Spare hardware currently in use:
WD Green 2TB in "meh" shape
ADATA 64Gigabyte SSD
Now I want to split that up and create two new machines: One daily driving work machine and a lean and mean (okay ... docile) gaming machine. The Working machine will be running Windows and the Gaming ... some kind of Windows, not sure but I have licenses for 7, 8.1 and 10 in professional or educational flavour.
Linux / Work
AMD FX-8320E with a noctua NH-U14S
motherboard to be determined
AMD/ATI R5 230 flex
16 Gigabyte of RAM
2TB harddrive to be determined
PSU to be determined
Windows / Gaming
AMD FX-4170 with AMD stock cooler
Gigabyte GA970-A D3
AMD/ATI HD 6870
WD Green 2TB
64Gigabyte SSD
Thermaltake PSU
So the list of parts I need is:
2TB Harddrive: must be 24/7 certified because I want to have fun with it for longer. I had to rescue data from a WD Green 2TB of a friend. Since spinnig rust is not dropping in price really I find the 10€/$ per Gigabyte premium for 24/7 capability a worthwhile investment. Budget is the 60-100$
AM3+ motherboard: I want a good AM3+ board. Compatible with the 8320E of course. There will NOT be any overclocking done
Must-have-features: USB 3.0 header, ATX form factor
Nice but not critical features: spare 4-PIN/PWM fan header, 6 SATA ports
utterly disinterested in: Gaming audio
Budget is 90-115$
alternatively If you find an amazing mATX AM3+ fitting everything but the ATX size above let me know
PSU: I would guess 400-500 Watts maximum
Must-have-features: quiet operation, 80+ something, plug fitting the motherboard CPU power (i.e. 4/6/8 pin)
Nice but not critical features: braided/sleeved 24 Pin cable, black cables would be cool
utterly disintersted: modularity, arcane USB control features, powder coated exteriour (blank casing is fine)
This one is a bit special since the PSU can be a system-builder PSU, which often lack the cables for SLI/Crossfire configs. My GPU will not need a PSU cable since it is entirely powered off the PCIe Slot (17 Watt peak power). A second SATA-power cable tree is not really nessecary since I have a bunch of Molex-SATA adapters. The Enermax PSU calculator recommends 321 Watt of Minimum PSU power so a 450 Watt will be fine. The system idle will probably be under 100 Watt.
Budget is 40-50$ ideally but willing to compromise
Hardware I already decided on but may be talked out of:
AMD stock cooler: If you know a cheap one for 125W TDP AM3+ let me know otherwise we will be running stock
Fractal core 2300: Depending on the CPU cooler I will shell out for the 2500. BUT! If you know an okay priced case looking like the fractal core series let me know.
Arcane/Strange Hardware I'm putting into the system:
PCI fan mounting solution to force-feed the GPU
PCI slot 2,5' HDD hot swap bay
5,25' slot 3,5' HDD hot swap bay
The ebay links are placeholders since they were in English and I did not want to confuse you with German Amazon links.
I do not have the money for the upgrade right now but I will be taking on a side job in the Semester break. Prices of all components probably won't move for the next half year (Socket AM3+ being old and HDDs and PSUs being stable in their pricing). So consider the budgets for the parts to be tolerant of moderate overspending.
TL;DR: I need:
well equipped AM3+ motherboard for non-overclocking purposes
400-500W PSU with 80+ Bronze does not have to be SLI/CF capable
2TB 24/7 certified 3,5' harddrive
AM3+ CPU cooler for 125W TDP, non overclocking
