OK, time to throw away our new motherboards, forget about Intel’s current guilty pleasures and go back to the days when Nehalem changed the #PCMR market with vast performance improvements and a redesigned architecture where it changed our overclocking habits. Well that was 10 years ago, and look where we are now; motherboards filled with RGB lighting, and designer clothing for computer motherboards. What if you’re that type of person who doesn’t buy into that bullshit? What if you want to go back to basics, and have a motherboard that functions and performs like an actual computer motherboard? You can either try hard and find a decent performing motherboard that hadn’t got all the frills and give you the helping hand that you only need…
Or, go back to Intel’s (don’t bash me) X58 platform; the age where motherboard manufacturers focused and competed on particular things; features that we may never use but will be Handy Andy to have, for example, Firewire 400/800 ports; and the race to the top of who can have the best overclocking experience like the true man.
Cut to the chase, yes you are free to go back to X58 but with one thing; do you know Spectre and Meltdown? If you do, then you do know that pretty much all the Nehalem chips are affected, and being a 10 year old platform, motherboard manufacturers have ceased support for these hardworking gems. But on the other camp, Intel has a microcode release that actually supports all the way back to the 1st gen Core micro-architecture; so Nehalems are supported - mostly - with a few with early steppings that might’ve not gotten the support and therefore, won’t be compatible with these custom BIOS ROMs for every X58 motherboards that comes with the microcode update, so double check to see what stepping your Nehalem micro chip has before applying the motherboard update.
Now I have downloaded the update for my Rampage II Extreme board my other system has, and I could flash mine using ASUS’ EZ Flash tool to do so, but haven’t done so yet, because I would want to backup the original BIOS first before proceeding (recommended for the rest of you). Some of you may have other methods of flashing motherboard ROMs so refer to you board’s manufacturer’s instructions on how to do that. And a bit of a warning - if it matters to you a lot: After you successfully applied the update, do expect some performance drops, due to the microcode patch having adverse effect on some of the processor’s instructions.
Here’s the link to all of the available custom BIOS ROMs. Do note this is an unofficial BIOS update so do proceed at your own risk, I will not be held responsible if things didn’t go well for you - but at least I will be responsible for my own fuck up, lol; best practice is to backup your BIOS, as I said earlier. And another note, these are pretty much every latest BIOS available for every Intel X58 based motherboards at the least but with the microcode chip update included with every single ROMs.
Last thing and I repeat, check your CPU stepping to see if it’s compatible with Intel’s microcode update otherwise your motherboard will be sent to the void.
