Hello,
I am running a kvm/qemu setup via libvirt where I am experiencing issues with bluetooth sound.
Problem Summary
When sound output from the guest is done via bluetooth, there is very noticable latency (up to a second I would guess), audible distortion, as well as short system freezes every now and then.
My Setup
- Ryzen 5900x on Gigabyte Aorus Master X570
- ASMedia ASM2142 PCIe USB 3.1 Controller
- TPLink UB 400 BT dongle
- Host: Arch Linux, 5.14.5
- Guest: Various Linux with same issues
libvirt XML
<domain xmlns:qemu="http://libvirt.org/schemas/domain/qemu/1.0" type="kvm">
<name>archlinux</name>
<uuid>bf75fc4c-7888-4d1e-b02e-ead9bd6b3d5b</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://archlinux.org/archlinux/rolling"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">29360128</memory>
<currentMemory unit="KiB">29360128</currentMemory>
<memoryBacking>
<hugepages/>
</memoryBacking>
<vcpu placement="static">12</vcpu>
<iothreads>2</iothreads>
<cputune>
<vcpupin vcpu="0" cpuset="6"/>
<vcpupin vcpu="1" cpuset="18"/>
<vcpupin vcpu="2" cpuset="7"/>
<vcpupin vcpu="3" cpuset="19"/>
<vcpupin vcpu="4" cpuset="8"/>
<vcpupin vcpu="5" cpuset="20"/>
<vcpupin vcpu="6" cpuset="9"/>
<vcpupin vcpu="7" cpuset="21"/>
<vcpupin vcpu="8" cpuset="10"/>
<vcpupin vcpu="9" cpuset="22"/>
<vcpupin vcpu="10" cpuset="11"/>
<vcpupin vcpu="11" cpuset="23"/>
<emulatorpin cpuset="0,12"/>
<iothreadpin iothread="1" cpuset="1,13"/>
<iothreadpin iothread="2" cpuset="2,14"/>
</cputune>
<os>
<type arch="x86_64" machine="pc-q35-5.2">hvm</type>
<loader readonly="yes" type="pflash">/usr/share/edk2-ovmf/x64/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/archlinux_VARS.fd</nvram>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
<vpindex state="on"/>
<synic state="on"/>
<stimer state="on"/>
<reset state="on"/>
<vendor_id state="on" value="1337"/>
<frequencies state="on"/>
</hyperv>
<kvm>
<hidden state="on"/>
</kvm>
<vmport state="off"/>
<ioapic driver="kvm"/>
</features>
<cpu mode="host-passthrough" check="none" migratable="on">
<topology sockets="1" dies="1" cores="6" threads="2"/>
<cache mode="passthrough"/>
<feature policy="require" name="topoext"/>
<feature policy="disable" name="svm"/>
</cpu>
<clock offset="utc">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0x15"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0x8"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="8" model="pcie-to-pci-bridge">
<model name="pcie-pci-bridge"/>
<address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
</controller>
<controller type="pci" index="9" model="pcie-root-port">
<target chassis="9" port="0x9"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x1"/>
</controller>
<controller type="pci" index="10" model="pcie-root-port">
<target chassis="10" port="0xa"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x2"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<input type="mouse" bus="virtio">
<address type="pci" domain="0x0000" bus="0x00" slot="0x0e" function="0x0"/>
</input>
<input type="keyboard" bus="virtio">
<address type="pci" domain="0x0000" bus="0x00" slot="0x0f" function="0x0"/>
</input>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<audio id="1" type="none"/>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</source>
<boot order="10"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x0f" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x0f" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x0b" slot="0x04" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x08" slot="0x01" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x10" slot="0x00" function="0x0"/>
</source>
<boot order="1"/>
<address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
</hostdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</memballoon>
</devices>
<qemu:commandline>
<qemu:arg value="-object"/>
<qemu:arg value="input-linux,id=mouse1,evdev=/dev/input/by-id/usb-Logitech_MX518_Gaming_Mouse_0379396D3438-event-mouse"/>
<qemu:arg value="input-linux,id=kbd1,evdev=/dev/input/by-id/usb-Kingston_HyperX_Alloy_FPS_Pro_Mechanical_Gaming_Keyboard-if02-event-kbd,grab_all=on,repeat=on"/>
</qemu:commandline>
</domain>
In search for a fix for my issue, I have experimented quite a lot with the CPU settings, so the above only reflects my most recent attempt, where I have also isolated the cores pinned to the VM.
In-Depth Problem Description
Sound over bluetooth with pulseaudio has high latency and slows down the system. It will be fine for some seconds, then I get a half-second long freeze, after which sound quality is abysmal with high latency. Running pulseaudio in superverbose mode, I get corresponding messages:
I: [bluetooth] module-bluez5-device.c: Changing bluetooth buffer size: Changed from 15360 to 14336
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 24
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 25
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 26
I: [bluetooth] module-bluez5-device.c: Changing bluetooth buffer size: Changed from 14336 to 13312
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 27
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 28
I: [bluetooth] module-bluez5-device.c: Changing bluetooth buffer size: Changed from 13312 to 12288
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 29
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 30
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 31
I: [bluetooth] module-bluez5-device.c: Changing bluetooth buffer size: Changed from 12288 to 11264
D: [bluetooth] module-bluez5-device.c: Skipping 521 us (= 92 bytes) in audio stream
I: [bluetooth] module-bluez5-device.c: Changing bluetooth buffer size: Changed from 11264 to 13312
D: [bluetooth] module-bluez5-device.c: Skipping 1276780 us (= 225224 bytes) in audio stream
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 23
I: [bluetooth] module-bluez5-device.c: Changing bluetooth buffer size: Changed from 12288 to 14336
D: [bluetooth] module-bluez5-device.c: Skipping 1775736 us (= 313240 bytes) in audio stream
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 18
I: [bluetooth] module-bluez5-device.c: Changing bluetooth buffer size: Changed from 14336 to 15360
D: [bluetooth] module-bluez5-device.c: Skipping 96712 us (= 17060 bytes) in audio stream
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 13
D: [bluetooth] module-bluez5-device.c: Skipping 37392 us (= 6596 bytes) in audio stream
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 8
D: [bluetooth] module-bluez5-device.c: Skipping 71451 us (= 12604 bytes) in audio stream
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 4
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 5
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 6
D: [bluetooth] a2dp-codec-sbc.c: Bitpool has changed to 7
The skipping messages line up with noticable stutters in audio.
When I skip pulseaudio entirely by playing a .wav directly through ALSA’s aplay (with help of https://github.com/Arkq/bluez-alsa), there seems to be no issue. It’s hard to gauge latency with an audio file alone, but I get no stutters with pure ALSA, while pulseaudio exhibits all those issues on the same audio file.
I have pretty much tried all the fixes w.r.t. pulseaudio found throughout the web:
load-module module-udev-detect tsched=0realtime-scheduling = nodefault-sample-rate = 48000
Because my Arch host has no such problems, this must be tied to the fact of being in a VM, but it is also extremely isolated to the specific issue of pulseaudio + bluetooth. Since sound output through the PCIe sound card works fine, I suspected the CPU configuration and whatever scheduling issues might come of it, but nothing I changed on that front had any effect.
I would appreciate your help!
