Issue
- The microphone outputs horrible white noise when the computer have been switched off for a while (few hours or more.) It's not background static, the noise is very loud and the microphone does not pic up any sounds while this is happening.
- If I disable the microphone, the white noise continues from other inputs on the device.
- To make it stop I have to unplug the usb connector from the pc and plug it back in. Then it boots up again and works fine. I can also restart the pc and it will stop. But if I turn the computer off and let it sit for a while, the issue is back when I boot back up.
Hopefully someone have some solutions, it's been like this for quite a while. Uninstalling drivers does not do anything, after reinstalling the same things happens again. It's also very frustrating to troubleshoot it since it has to sit for a while with the computer off to replicate the issue.
-anti
